guys whip me up an awesome build that i would get when i have my own job im only 14 looool
price limit is 1500 intel cpu and nvidia gpu plz i need everything :D
this is going to be a baseline to supply myself with ideas plz help
perhaps something like this?
http://pcpartpicker.com/p/DoIL
a little bit over $1500 but more than worth it, and less than that if you already have windows, if needed you could cut down the cpu cooler a bit, possibly something like a Noctua NH-D14 but that would be a VERY tight fit with this case.
thank you very much
btw this post is still open anyone else got ideas please feel free to comment
Newb, I just recently built something almost entirely identical to that rig, for the money, its the fastest thing I could find. Plays everything you could want maxed on a single monitor, 60FPS locked.
Taking into account that you're only 14. I highly suggest you look into other builds rather than Intel/Nvidea only..AMD builds can really stay on par with Intel upto i7's, but at that point the price tag is $2k+ for the build.
For this budget, you could do something like this: http://pcpartpicker.com/p/DpiE
I'm not all that good at configuring high budget builds, so no doubt some other guys could knock something together that slaughters everything.
craig.....................
you are a genius i would definitely take that into consideration
however i would downgrade the cpu a bit and get myself an aftermarket cooler
stock heatsink on the 8350 is... "hell'
Well..With 1.5K to spend there really is no need to downgrade..I mean, what's an extra $40-$70 at this point?
i kinda dont want to spend any extra cuz i would be on a tight budget at that time but i could always stick with the stock heatsink for a while
Take into consieration what parts/prices may be available when you intend to build this thing, it could end up costing like $800 in a few years, but perform terribaly in comparison with parts that come out in the next few years.
tight budget as in cant spend much more than that
yea that would be a long time from now but i kinda wanted an idea of what to get for it now but change later on but thanks anyway thats all the help i needed
No problem, and remember to keep up to date with prices in relation to performance, that is really what makes builds worth it in the end.
This will smash any current game, and has alot that can be moved into a new pc in the future. (Case is nice, SSD, HDD, Really nice PSU).
http://pcpartpicker.com/p/DqVc
Edit: As an intel/nvidia guy, this is a better build right now. Gives you alot more power for less money.
