Well, my heads been down getting paying work done, so not much change. Thought I’d show the tool store bit how it is now, getting ready to throw it all in the storage bit. Just need to fit a door, do the flooring and then it can all shove in there and I’ll have my office back again…only took 7 months
Next should be a new internal stud wall, for the potential WC and mini-kitchen…or server/PC room!
The storage door has arrived! So soon I’ll have it installed, once I’ve re-run electric. Then tools can get out the office and it’ll become less industrial.
I’ve got to admit, it’s a nicely made door, though quite heavy at around 55 KG/120 lbs, so I wonder how I’m going to get it installed. Most doors are less than a quarter, but this one comes with the frame and door locked together.
My admitted fail is that I had to switch the power off…while I was 13% done with testing a new drive. I have never worked so quickly while depending on the UPS to give me 3-5mins to safely disconnect the surplus electric cable. And why did I have to do that…ummm, the cable was passing through the door opening that’s having a new door, so it had to go!
I didn’t fancy re-starting the test, it had already taken nearly 24 hours just to get 13% of the drive (14TB) tested
Cheers mate, very kind to ask. I’m all good, I took my time as it’s a heavy lump if it falls. Glad you like to follow it…and that I’m not wasting time by sharing
Did the final fitment a few hours ago, lock is working and door perfectly plumb (after some minor adjustment).
Wow, you do have my sympathies…but it is an organised mess for sure
It’s funny, I look at houses for a living so I don’t see mess, just walls, openings, floors & ceilings, but one thing that catches my eye is the growing e-waste pic…and the huge number of CAT cables you have coming out the wall. What’s that all about then?!? Are they CAT?
3 are Displayport over Fiber, but the rest are all CAT6. I rack all my gear and then use a local KVM so I can plug my work laptop into the same keyboard, monitor, and mouse. So some of the CAT6 cables are for USB extensions, and they I have a few different devices that require wired network like my work IP phone (POE powered).
What you dont see is that I have another 3 in the ceiling along with 4 RG6 drops.
Cheers for that. I’d really like to look into KVM’s in general, my only experience of them is where two machines are side by side and there’s a KVM switch between them. Crikey, you’ve got a healthy amount of cabling there
