(UK) £600 Gaming Pc build for 2014!
All on Amazon.co.uk
Fractal Design Define R4 PC Case - Black/Pearl
Corsair Builder Series CXM 600W Modular 80 PLUS Bronze Certified ATX/EPS PSU
Intel i5-3330 Ivybridge Box Core i5 Processor (3GHz, 6MB Cache, Socket LGA 1155)
Asus P8Z77-V LX Motherboard (Socket 1155, 32GB DDR3 Support, ATX, Intel Z77 Express, USB 3.0, CrossFireX Support, Dual Intelligent Processors 3)
Gigabyte NVIDIA GTX660 2GB DDR5 PCI-E Graphics Card
Western Digital 1TB internal Hard Drive - Caviar Blue (3.5 inch)
LiteOn IHAS124-04 24x SATA Half Height Internal DVDRW Drive - Black
Crucial BLT2CP4G3D1608DT1TX0CEU 8GB (2x 4GB) Ballistix Tactical Memory
Not bad at all!
What are you going to do with the PC and are you set on using Amazon?
http://uk.pcpartpicker.com/p/1UOiE
CPU: AMD FX-6300 3.5GHz 6-Core Processor (£79.99 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£23.98 @ Scan.co.uk)
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard (£59.00 @ Amazon UK)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory (£59.99 @ Novatech)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£47.99 @ Amazon UK)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case (£76.97 @ Ebuyer)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply (£49.24 @ CCL Computers)
Optical Drive: Lite-On iHDS118-04 DVD/CD Drive (£10.86 @ Scan.co.uk)
Other: MSI HD7950 TwinFrozr iii OC (£192.00)
Total: £600.02
i do not mind using ebuyer as well. I am going to play good games like Planetside 2.
Thanks! I will compare your suggestion with others!
