Uhh, how does one define this screen issue?
So, this just happened. How does one define this issue. LCD color bleed? I have no idea, and need some help. It is like one of those modern art pieces you see in galleries, I did check, and it does not appear to happen in pixels.
It looks as if you got water in the LCD and it now has layers of water between the polarized films I suppose just water damage or if anything is has had physical damage from hitting it with an object of some sort.
The phone was not physically damaged or wet. Nonetheless, I have put the phone in rice and hope that it helps. I will take it to my cellphone operator as i bought it from there.
Could have just been a fault from the manufacture's QC that was not thoroughly tested.
