Your running 1.7V on the vcore. Tone that shit down. Jesus fuck. Stock voltage dosent get that much past 1.2v and a standard overclock on air is recomended under 1.4. Hell even liquid nitrogen guys stop at about 1.7-1.8. I have maxed on 1.66 on my 4770k on water and I was hitting high 90's. Reset your overclock to default and start again. Aim for best overclock with a max voltage of 1.4v and you will be fine.
Seriously 1.7v is idiotic past benchmarks and even then if you dont know what your doing its risky. Plenty of CPU's have died from much less.
Even phantom with his 5GHz 4670k had issues with heat at 1.6v the one time he overvolted that high and hes on a custom loop.
Drop that shit down before you burn out your CPU and or mobo
1.7v omfg! holy shit, that high for any sustained period is chip killing territory. Suicide runs on ln2 or phase change - yeah go for it, everyday. no no no
Chances are you have damaged the cpu or at bare a bare minimum ruined any chance of a decent stable overclock with moderate voltage.
It wouldve been throttling core big time ~ fps drop.
I wouldnt go as far as saying its damaged. people underestimate what haswell can handle but its also all on a chip by chip bases. I know of people still running 1.6v on a custom loop and have done for months but I also know of people who pushed their 4770k to 1.3v and fried their chip
in the bios everything is fine. Core voltage seems to be about right and imput voltage is to spec as well. Got CPU-Z installed? It will give us a better idea on the vcore.
I would say cpu-z is more reliable. If the voltage ios not the issue then im thinking your looking at a disloged heat spreader. You may want to look at getting it RMA'd if ou dont have another rig to test it on. Sounds like something has gone wrong.
It's weird though coz in bios it says that core voltage 1.07 and Cpu input voltage is 1.70, like what;s the difference?
It shouldn't be though coz I've already replaced the heatsink and used good thermal compound and both coolers gave the same results, maybe 5c better on the new one..
And if I do RMA then what exactly do I RMA? The Mobo or the CPU?
