So I’ve heard of peplechangin a single bit to enable/disable things like intels’ ME; I assume there was no change to what’s visible in UEFI settings and it was all changed behind the scenes. I’m wondering about doing the same for above 4GB decoding. Might be the same for same generation parts; so find that bit on a board that supports it, and flash it to the appropriate default value with an external programmer.
I suspect the GUI side is the more proprietary part from board to board.
I’m willing to at least contribute to the effort with a couple sandy/ivybridge server board firmware dumps. Both support it already; I suspect the the single socket intel branded board would be more useful… could mod X79 board and maybe the consumer socket sandy/ivy bridge boards with that info.
Most of the work around Intel ME disabling revolves around the me_cleaner project:
The bit you refer to is either HAP or AltMeDisable,
Looking at the code and documentation there may be a good starting point.
