Has anyone here been able to get the onboard wireless working with the Taichi X570 in Ubuntu or Pop!_OS?
My installations can’t even recognize that there is a wireless adapter. Googling has not been helpful as yet…
No luck here on 18.04 or 19.04.
I’m having the same problem on ASRock X570 Phantom Gaming ITX/TB3. Can’t find any WiFi or BT adapter on Ubuntu 19.10 or Manjaro 18.1.1.
[edit]
In my situation it actually looks like there’s something wrong with the motherboard or BIOS.
It’s likely a Intel AX chip and it requires the firmware to be installed along with either a backport of iwlwifi
or a kernel newer than 5.1.
[Solved]
I guess it was just a question of waiting…
You are right. It needed the backport of iwlwifi
