I’m running out of ideas here and hope someone will have some good input.
I’m running Ubuntu Gnome 17.04. my boot drive is 250GB. 500MB each for /boot
and /boot/efi
, and the rest is formatted as crypt-luks. 32GB of that is swap, then 15GB each for /var
and /tmp
, and the rest is /
My /home
directory is a second 250GB drive.
A few days ago, ubuntu started showing me notices about running out of disk space. I get a warning about “only {small number like 500MB} remaining on filesystem root.” I’m even starting to get errors from some commands that write to /tmp
about having no space left to write. However, disk usage analyzer shows i’m only using ~ 8GB.
I opened up gparted and it tells me that the crypt-luks partition isn’t mounted. This doesn’t make sense — I can access files, run programs, and so forth. There’s a message,
Warning: Linux Unified Key Setup encryption is not yet supported.
…which I don’t remember seeing before, but encryption is set up successfully on boot (and, as noted above, reading/writing files works just fine).
Any suggestions? Appreciate it!
edit
ok, a discovery:
~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 16G 0 16G 0% /dev
tmpfs 3.2G 11M 3.2G 1% /run
/dev/mapper/ubuntu--gnome--vg-root 196G 185G 1.1G 100% /
tmpfs 16G 82M 16G 1% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 16G 0 16G 0% /sys/fs/cgroup
/dev/sdb1 234G 150G 73G 68% /home
/dev/sda1 235G 85G 139G 38% /mnt/phison-white
/dev/nvme0n1p2 465M 151M 286M 35% /boot
/dev/nvme0n1p1 511M 3.4M 508M 1% /boot/efi
tmpfs 3.2G 16K 3.2G 1% /run/user/120
tmpfs 3.2G 44K 3.2G 1% /run/user/1000
what’s up with /dev/mapper
? is it reporting corrcet usage? how do i find what’s taking up all this space, if so?
