Ubuntu KVM Issues - SOLVED
Specs:
Motherboard: ASRock Taichi X470
CPU: 2700x
RAM: 32GB Gskill ripjaws
I followed Wendell’s guide basically step by step. I had to blacklist the nouveau module because it kept taking control over the second GPU every time I booted. Other than that, I followed it perfectly. And whenever I open virt-manager, I get this message
Screenshot%20from%202018-08-18%2017-58-31
Yes, virtualization is enabled on the motherboard. I booted into Windows, and it said virtualization is enabled. I honestly have no clue what to do from here. Plz help.
Edit: Pretty sure the board is fucked, getting it replaced.
Edit 2: Yep, it was the board. Just went to Microcenter and swapped it out for an Asus X470-PRO. Booted it up and everything works.
Did you install qemu-kvm?
Better check in UEFI/BIOS if it’s actrually turned on not that just MB has the feature.
I did that already.
