Ubuntu help gpu bypass
how can i bypass the dysply out on my quadtro 600 on ubuntu pc. i get a werid res when i use the the dysply out on the quadtro in Linux but win 10 no prob. is there away just to use the 775 intagrated gpu for the dsiply but use the gpu for the power. thanks.
Sure, you can use IGP for host and Quadro for guest, (its called gpu passthrough btw. if you need search term) But you need proper support for VT-d on your CPU and motherboard,
Also you can find guides for Ubuntu on this very forum. Look in vfio category.
