{Ubuntu Gnome} Icons Help
Hello, I was wondering how you change the icon pack On gnome, and what are some good icon packs to use ?
~Regards Z3RO
I would use this website to find icon packs: http://gnome-look.org/
Make sure you have gnome-tweak-tool installed. If not do sudo aptitude install gnome-tweak-tool
From there you can use the "tweak tool" to install the icon packs, GTK themes, gnome-shell themes that you download from the site that I linked to above. If you need any other help either google around or message me on here.
Thanks man. I got it to work
~Regards Z3RO
Nice!!!
