I’m new to Linux. I’m using Ubuntu 18.04 and was wondering if there is any way to make a keyboard shortcut to enable the color effects option in the screen magnifier that is built into Ubuntu.
Thanks
Thanks
Not according to this
https://help.ubuntu.com/stable/ubuntu-help/keyboard-shortcuts-set.html.en
But in theory all you need to know is what the command is to toggle the switch you want and then bind a keyboard shortcut to it.
Trick is finding the program / command. Not sure how to do that presently.
