Ubuntu 18.10 AMD RX580 5 Monitors Issue
I installed Ubuntu 18.10 yesterday, and ran into a problem with my 5 monitor setup. I bought a 4 port displayport adapter that connects to 4 of my monitors. All monitors attached to the displayport adapter show up fine, but my 5th monitor will not stay on.
The 5th monitor actually comes up, and is where my login screen is when signing in, but once I’m in Ubuntu 18.10 that monitor goes black. I can enable it is display settings, but it disappears right away.
I have an RX580 in my computer, but AMDGPU-Pro Driver for Linux Ubuntu doesn’t look like it works for Ubuntu 18.10. Should I downgrade or is there a work around I didn’t see while researching the issue?
Any ideas would be much appreciated!!
sounds like your graphics card does not support that configuration.
you could try not using the splitter and try to connect each monitor directly to the graphics card.
It worked under windows so I figured it’d work under Linux, but I’ll give that a shot. Thanks!
Removing the displayport adapter worked. All 5 monitors are showing now!
