I created windows 10 1709 VM and have 1080Ti passthrough with few USB ports , Ryzen host CPU , separate USB audio card, xbox 360 wifi controllers, separate monitor 1440p60Hz
When i do cinebench test it is flawless and fast ~1730 CPU , 3dmark GPU Timespy score is ~9300 , Firestrike test crashed.
VM game results: Battlefront 2 with ~15 FPS , Witcher 3 ~15 FPS with huge drops, Starcraft 2 ~100FPS , HoTS ~100 FPS with some drops to ~50.
Bare metal windows 10 results: Battlefront 2 with ~100+ FPS , Witcher 3 ~80-115 FPS,Starcraft 2 ~100+FPS , HoTS ~120-250 FPS
All tests are on stock clock CPU and GPU , Memory is in XMP @3000MHz , Rzyen 2700x, Crosshair Hero VII , 2x1080Ti ROG Strix Gaming OC. Ubuntu 18.04 with kernel 4.18.
I disabled NPT and got awful CPU speed but got following results GPU:
Battlefront 2 with ~20-65 FPS , Witcher 3 ~70 FPS with huge drops, Starcraft 2 ~100FPS , HoTS ~120 FPS with some drops to ~50.
I am not @ PC atm but can add every bit of needed configuration just let me know.
I am actually linux sysadmin with lots of XP but not with linux gaming and AMD (first ever amd product) , my work virtualization is mostly proxmox on blades and supermicro headless , cli only and intel only. I actually have supermicro server at home with proxmox for all my inhouse needs too.
I was hoping i could use Linux @ home without booting into windows for gaming.
Also my 2 GPU’s have indentical ID’s so i had to reserve the second GPU via driver_override .
Thanks in advance guys , love the forum so far.
my virsh xml :
<domain type='kvm'> <name>win10_glavni</name> <uuid>383a7493-071e-4431-817c-da885f279fa8</uuid> <memory unit='KiB'>10264576</memory> <currentMemory unit='KiB'>10264576</currentMemory> <vcpu placement='static'>10</vcpu> <os> <type arch='x86_64' machine='pc-q35-2.11'>hvm</type> <loader readonly='yes' type='pflash'>/usr/share/OVMF/OVMF_CODE.fd</loader> <nvram>/var/lib/libvirt/qemu/nvram/win10_glavni_VARS.fd</nvram> <boot dev='hd'/> <bootmenu enable='yes'/> </os> <features> <acpi/> <apic/> <hyperv> <relaxed state='on'/> <vapic state='on'/> <spinlocks state='on' retries='8191'/> <vendor_id state='on' value='whatever'/> </hyperv> <kvm> <hidden state='on'/> </kvm> <vmport state='off'/> </features> <cpu mode='host-passthrough' check='none'> <topology sockets='1' cores='5' threads='2'/> </cpu> <clock offset='localtime'> <timer name='rtc' tickpolicy='catchup'/> <timer name='pit' tickpolicy='delay'/> <timer name='hpet' present='no'/> <timer name='hypervclock' present='yes'/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>destroy</on_crash> <pm> <suspend-to-mem enabled='no'/> <suspend-to-disk enabled='no'/> </pm> <devices> <emulator>/usr/bin/kvm-spice</emulator> <disk type='file' device='disk'> <driver name='qemu' type='qcow2'/> <source file='/mnt/Virtualke/win10_glavni.qcow2'/> <target dev='vda' bus='virtio'/> <address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/> </disk> <disk type='file' device='cdrom'> <driver name='qemu' type='raw'/> <source file='/home/sglumac/Downloads/Win10_1709_English_x64.iso'/> <target dev='sda' bus='sata'/> <readonly/> <address type='drive' controller='0' bus='0' target='0' unit='0'/> </disk> <disk type='file' device='cdrom'> <driver name='qemu' type='raw'/> <source file='/home/sglumac/Downloads/virtio-win-0.1.141.iso'/> <target dev='sdb' bus='sata'/> <readonly/> <address type='drive' controller='0' bus='0' target='0' unit='1'/> </disk> <controller type='usb' index='0' model='ich9-ehci1'> <address type='pci' domain='0x0000' bus='0x00' slot='0x1d' function='0x7'/> </controller> <controller type='usb' index='0' model='ich9-uhci1'> <master startport='0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x1d' function='0x0' multifunction='on'/> </controller> <controller type='usb' index='0' model='ich9-uhci2'> <master startport='2'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x1d' function='0x1'/> </controller> <controller type='usb' index='0' model='ich9-uhci3'> <master startport='4'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x1d' function='0x2'/> </controller> <controller type='sata' index='0'> <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/> </controller> <controller type='pci' index='0' model='pcie-root'/> <controller type='pci' index='1' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='1' port='0x10'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0' multifunction='on'/> </controller> <controller type='pci' index='2' model='dmi-to-pci-bridge'> <model name='i82801b11-bridge'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x1e' function='0x0'/> </controller> <controller type='pci' index='3' model='pci-bridge'> <model name='pci-bridge'/> <target chassisNr='3'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/> </controller> <controller type='pci' index='4' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='4' port='0x11'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x1'/> </controller> <controller type='pci' index='5' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='5' port='0x12'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x2'/> </controller> <controller type='pci' index='6' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='6' port='0x13'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x3'/> </controller> <controller type='pci' index='7' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='7' port='0x14'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x4'/> </controller> <controller type='pci' index='8' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='8' port='0x15'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x5'/> </controller> <controller type='pci' index='9' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='9' port='0x16'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x6'/> </controller> <controller type='virtio-serial' index='0'> <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/> </controller> <interface type='network'> <mac address='52:54:00:01:e8:99'/> <source network='default'/> <model type='virtio'/> <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/> </interface> <serial type='pty'> <target type='isa-serial' port='0'> <model name='isa-serial'/> </target> </serial> <console type='pty'> <target type='serial' port='0'/> </console> <channel type='spicevmc'> <target type='virtio' name='com.redhat.spice.0'/> <address type='virtio-serial' controller='0' bus='0' port='1'/> </channel> <input type='tablet' bus='usb'> <address type='usb' bus='0' port='1'/> </input> <input type='mouse' bus='ps2'/> <input type='keyboard' bus='ps2'/> <graphics type='spice' autoport='yes'> <listen type='address'/> <gl enable='no' rendernode='/dev/dri/by-path/pci-0000:09:00.0-render'/> </graphics> <sound model='ich6'> <address type='pci' domain='0x0000' bus='0x03' slot='0x01' function='0x0'/> </sound> <video> <model type='qxl' ram='65536' vram='65536' vgamem='16384' heads='1' primary='yes'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/> </video> <hostdev mode='subsystem' type='pci' managed='yes'> <source> <address domain='0x0000' bus='0x0a' slot='0x00' function='0x0'/> </source> <address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0'/> </hostdev> <hostdev mode='subsystem' type='pci' managed='yes'> <source> <address domain='0x0000' bus='0x0a' slot='0x00' function='0x1'/> </source> <address type='pci' domain='0x0000' bus='0x07' slot='0x00' function='0x0'/> </hostdev> <hostdev mode='subsystem' type='pci' managed='yes'> <source> <address domain='0x0000' bus='0x0b' slot='0x00' function='0x3'/> </source> <address type='pci' domain='0x0000' bus='0x09' slot='0x00' function='0x0'/> </hostdev> <redirdev bus='usb' type='spicevmc'> <address type='usb' bus='0' port='2'/> </redirdev> <redirdev bus='usb' type='spicevmc'> <address type='usb' bus='0' port='3'/> </redirdev> <memballoon model='virtio'> <address type='pci' domain='0x0000' bus='0x08' slot='0x00' function='0x0'/> </memballoon> </devices> </domain>
Kernel : 4.18.0-13-generic
/etc/default/grub : GRUB_CMDLINE_LINUX="amd_iommu=on iommu=pt rd.driver.pre=vfio-pci kvm_amd.npt=1"
/etc/modprobe.d/vfio.conf : install vfio-pci /sbin/vfio-pci-override-vga.sh options vfio-pci ids=1022:145f
/sbin/vfio-pci-override-vga.sh : echo "vfio-pci" > /sys/devices/pci0000:00/0000:00:03.2/0000:0a:00.0/driver_override modprobe -i vfio-pci
/etc/modules-load.d/vfio-pci.conf : vfio-pci
/etc/dracut.conf.d/vfio.conf : add_drivers+=" vfio vfio_iommu_type1 vfio_pci vfio_virqfd " install_items+=" /sbin/vfio-pci-override-vga.sh /usr/bin/find /usr/bin/dirname "
