Hi everyone
I’m new to this forum so sorry in advance if i do something wrong:joy:
i’m fairly new to the linux system and i have issues with flash player on HBO and i have tied install flash and tried 3 different web browser and it still won’t work…
And for the second issue i have is with gaming.
i play csgo for the most part and it doesn’t goes as smoothly as i want.
I have some tearing and lagg on graphics.
My hardware is:
Intel Core i7-5820K Processor
Crucial DDR4 2133MHz 8GB
MSI GeForce GTX 970 Gaming 4GB
any suggestions on what i can do to fix it?
Dumb question, but are you sure you need Flash? It’s been a very, very long time since I’ve had to install Flash for anything on Linux. Since the advent of HTML5, video is natively supported, and even sites that use DRM can work without Flash.
To use it, you’ll need the “Wildvine” plugin (for Chromium), or you’ll need to enable Wildvine in Firefox under Preferences. The option is “Play DRM content”.
I have some tearing and lagg on graphics […] nvidia
By default, Ubuntu ships with the community-developed ‘nouveau’ video driver for GeForce cards. Open up the Software Center, and check the Driver’s tab. Make sure you’ve enabled the proprietary nvidia driver. Once that installs, you’ll need to reboot to used them.
The Nouveau driver works for basic desktop tasks, but otherwise has bad performance and isn’t suitable for gaming.
You’ll also want the nvidia-settings package, which is a GUI for controlling Nvidia settings. Make sure “Force Composition Pipeline” and “Force Full Composition Pipeline” are both enabled in there. (Note: This can cause a performance drop in some cases. Disable if if you hit one.)
Which browsers did you try? My first debugging step is to download chrome. Not chromium, but the binary, unfree, google version. If it works OOTB with Chrome, it’s a library problem.
Which GPU drivers are you using on your 970? Did you install the proprietary drivers?
You probably want the 3rd party GPU drivers repo:
sudo add-apt-repository ppa:graphics-drivers
Then you can update your repository caches and install:
sudo apt update
sudo apt install nvidia-390
Then, to make sure nothing happens to them without your intervention:
sudo apt-mark hold nvidia-390
i tried play DRM content in firefox and it didn’t work and for chromium i couldn’t find the plugin…
for the driver i have already done what u have said but i couldn’t fine the “Force Composition Pipeline” and “Force Full Composition Pipeline” in the Nvidia settings…
i tried with firefox, chrome and chromium and didn’t work on either of them.
and for the gpu driver i have already done that are there anything else i could try?
Interesting…
You’ve installed it, but you may not have it running, let’s verify that it is. Can you give me the output of lspci -k
? That will show all the devices on your system and what modules they’re using. The bit I’m interested in might look something like this:
0e:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070 Ti] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] Device c303
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
0e:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
Sometimes, even though you’ve got the nvidia driver installed, the open source (nouveau) driver is still running by default.
There are a few options in the nvidia settings we can try once we’ve verified the drivers are actually running.
Uhh, I’m really not the best when it comes to fixing browser issues. I usually just throw my hands up and make a help thread.
I remember something about needing to enable DRM features on Firefox for Netflix to work, it’s possible HBO has a similar problem, or they may block linux based on User Agent.
It might be worth trying to spoof your user agent to whatever browser you’re using, but make it think you’re running on OSX or Windows. If you have similar results, you know it’s the library and not HBO discriminating against you for your love of penguins.
I don’t have an HBO subscription, otherwise I’d try to duplicate your issue. If there are “freebies” I can use to test, I’d be happy to.
00:00.0 Host bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DMI2 (rev 02)
Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E7 v3/Xeon E5 v3/Core i7 DMI2
00:01.0 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 1 (rev 02)
Kernel driver in use: pcieport
Kernel modules: shpchp
00:01.1 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 1 (rev 02)
00:02.0 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 2 (rev 02)
00:02.2 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 2 (rev 02)
00:02.3 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 2 (rev 02)
00:03.0 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 3 (rev 02)
00:05.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Address Map, VTd_Misc, System Management (rev 02)
Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E7 v3/Xeon E5 v3/Core i7 Address Map, VTd_Misc, System Management
00:05.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Hot Plug (rev 02)
Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E7 v3/Xeon E5 v3/Core i7 Hot Plug
00:05.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 RAS, Control Status and Global Errors (rev 02)
Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E7 v3/Xeon E5 v3/Core i7 RAS, Control Status and Global Errors
00:05.4 PIC: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 I/O APIC (rev 02)
Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E7 v3/Xeon E5 v3/Core i7 I/O APIC
00:11.0 Unassigned class [ff00]: Intel Corporation C610/X99 series chipset SPSR (rev 05)
Subsystem: Micro-Star International Co., Ltd. [MSI] C610/X99 series chipset SPSR
00:14.0 USB controller: Intel Corporation C610/X99 series chipset USB xHCI Host Controller (rev 05)
Subsystem: Micro-Star International Co., Ltd. [MSI] C610/X99 series chipset USB xHCI Host Controller
Kernel driver in use: xhci_hcd
00:16.0 Communication controller: Intel Corporation C610/X99 series chipset MEI Controller #1 (rev 05)
Subsystem: Micro-Star International Co., Ltd. [MSI] C610/X99 series chipset MEI Controller
Kernel driver in use: mei_me
Kernel modules: mei_me
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection (2) I218-V (rev 05)
Subsystem: Micro-Star International Co., Ltd. [MSI] Ethernet Connection (2) I218-V
Kernel driver in use: e1000e
Kernel modules: e1000e
00:1a.0 USB controller: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #2 (rev 05)
Subsystem: Micro-Star International Co., Ltd. [MSI] C610/X99 series chipset USB Enhanced Host Controller
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation C610/X99 series chipset HD Audio Controller (rev 05)
Subsystem: Micro-Star International Co., Ltd. [MSI] C610/X99 series chipset HD Audio Controller
00:1c.0 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port #1 (rev d5)
00:1c.4 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port #5 (rev d5)
00:1d.0 USB controller: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation C610/X99 series chipset LPC Controller (rev 05)
Subsystem: Micro-Star International Co., Ltd. [MSI] C610/X99 series chipset LPC Controller
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation C610/X99 series chipset 6-Port SATA Controller [AHCI mode] (rev 05)
Subsystem: Micro-Star International Co., Ltd. [MSI] C610/X99 series chipset 6-Port SATA Controller [AHCI mode]
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation C610/X99 series chipset SMBus Controller (rev 05)
Subsystem: Micro-Star International Co., Ltd. [MSI] C610/X99 series chipset SMBus Controller
Kernel modules: i2c_i801
02:00.0 Non-Volatile memory controller: Intel Corporation Device f1a5 (rev 03)
Subsystem: Intel Corporation Device 390a
Kernel driver in use: nvme
Kernel modules: nvme
06:00.0 VGA compatible controller: NVIDIA Corporation GM204 [GeForce GTX 970] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] GM204 [GeForce GTX 970]
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
06:00.1 Audio device: NVIDIA Corporation GM204 High Definition Audio Controller (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] GM204 High Definition Audio Controller
08:00.0 USB controller: ASMedia Technology Inc. ASM1142 USB 3.1 Host Controller
Subsystem: Micro-Star International Co., Ltd. [MSI] ASM1142 USB 3.1 Host Controller
ff:0b.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring (rev 02)
Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring
ff:0b.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring (rev 02)
Kernel driver in use: hswep_uncore
ff:0b.2 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring (rev 02)
ff:0c.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers
ff:0c.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
ff:0c.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
ff:0c.3 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
ff:0c.4 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
ff:0c.5 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
ff:0f.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Buffered Ring Agent (rev 02)
ff:0f.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Buffered Ring Agent (rev 02)
ff:0f.4 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers (rev 02)
Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers
ff:0f.5 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers (rev 02)
ff:0f.6 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers (rev 02)
ff:10.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface
ff:10.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface (rev 02)
ff:10.5 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers
ff:10.6 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers (rev 02)
ff:10.7 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers (rev 02)
ff:12.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0
ff:12.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 (rev 02)
ff:13.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers
ff:13.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers (rev 02)
ff:13.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder
ff:13.3 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder (rev 02)
ff:13.4 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder (rev 02)
ff:13.5 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder (rev 02)
ff:13.6 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Channel 0/1 Broadcast (rev 02)
ff:13.7 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Global Broadcast (rev 02)
ff:14.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 Thermal Control (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 Thermal Control
ff:14.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 Thermal Control (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 Thermal Control
ff:14.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 ERROR Registers (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 ERROR Registers
ff:14.3 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 ERROR Registers (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 ERROR Registers
ff:14.6 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 (rev 02)
ff:14.7 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 (rev 02)
ff:15.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 Thermal Control (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 Thermal Control
ff:15.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 Thermal Control (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 Thermal Control
ff:15.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 ERROR Registers (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 ERROR Registers
ff:15.3 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 ERROR Registers (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 ERROR Registers
ff:16.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 1 Target Address, Thermal & RAS Registers (rev 02)
ff:16.6 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Channel 2/3 Broadcast (rev 02)
ff:16.7 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Global Broadcast (rev 02)
ff:17.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 1 Channel 0 Thermal Control (rev 02)
ff:17.4 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 (rev 02)
ff:17.5 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 (rev 02)
ff:17.6 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 (rev 02)
ff:17.7 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 (rev 02)
ff:1e.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit
ff:1e.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit (rev 02)
ff:1e.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit (rev 02)
ff:1e.3 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit (rev 02)
ff:1e.4 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit (rev 02)
ff:1f.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 VCU (rev 02)
ff:1f.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 VCU (rev 02)
For the browser issue… I would recommend downloading widevine (which is google’s HTML5 DRM). Although this should be included with the Chrome install from their site.
Also, I had to install chromium ffmpeg codecs to get it working.
sudo apt update && sudo apt install chromium-codecs-ffmpeg-extra
I would google both of these to get specific instructions for ubuntu.
i did the update and the install and i didn’t work.
here is what i get on each browser
Firefox: Gah. Your tab just crashed
chrome: black screen but i see the title of the series im trying to play.
chromium: Adobe flash player is out of date.
is there anything else i can try?
On Chromium, you have to fake the user agent to get Netflix or any Widevine stuff to load.
You’re gonna have to use the purpose built Chromium with the patches to allow Widevine to run:
https://launchpad.net/~saiarcot895/+archive/ubuntu/chromium-dev
Install this, then download the latest Chrome dev version package. Don’t install it, extract the widevine .so files from the chrome dev package and place them in ~/.config/chromium
Then change your user agent in Chromium using the “User Agent Switcher” extension to this:
Mozilla/5.0 (X11; Ubuntu; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/(current chromium version, from "About Chromium") Safari/537.36
Netflix should work now.
