Ubuntu 13.10 display issues with HD 7990
Hey all,
I wanted to try out Ubuntu for the first time and have managed to install 13.10 to separate hard drive. I believe the install for the OS has completed successfully but there seems to be a problem with the display driver, I'm guessing.
This is what I see when booting into Ubuntu 13.10:
http://s1371.photobucket.com/user/Theblackrain1/media/DSC_0034_zps5f209b96.jpg.html
I have a cursor but obviously can't see what i'm clicking and have no idea how to fix this. Is this a compatibility issue with my 7990?
I'm a noob when it comes to Linux so if anyone has any suggestions or advice in layman's terms, please let me know.
Thanks.
Try upgrading to 14.04 LTS or try a new linux OS and then update the drivers. I used Zorin 8 os before and it is amazing for games.
Before you try figuring out what's wrong, I would install a distro that is long term support or a rolling release. 13.10 is almost end of life. If you want to stay with something Ubuntu based, I would go with Xubuntu.
Open source AMD drivers and crossfire. I have seen exactly that with multiple distros when I try and boot with both my 7950s active while using the open source drivers. You either need to try and install a command line distro and install the catalyst drivers that way (or boot off of just your integrated GPU, if you have one), or somehow disable one of the GPUs.
