Hi Guys , I shipped my 7970 to a friend and oh boy the delivery guy's must had fun playing rugby with the box , so it arrived with some 1mm by 2mm condensers that I cannot find the place where they go , and tried to talk to sapphire because the card is no longer in its warranty , here is my exp: PS : the time line is upside down ..ps2: My native language is not english so excume me
2016-8-5 [11:30]
11187-04 contains several board P/N numbers and we are not able to provide us the schematics due to the confidential.
Thanks.
2016-8-4 [21:09]
Hi i think i am not making my self very clear about my issue...
I just wanted a 11197-04 schematics for me to check were are some condensers missing , me as the card does not have guarantee ,
If you guys are not understanding the number i will describe the card
7970 dual x oc with boost - the card as a blue pcb 2x8pin power connectors and 1xHDMI; 1xDisplayPort; 1xSingle-Link DVI-D; 1xDual-Link DVI-I
I think is the only 7970 that as a dual x cooler with 2x8pin and a blue pcb .
Or can you tell me how much would it be to fix the card
2016-8-4 [17:21]
Or you can tell us the spec of those two components so that we can check the database for you.
2016-8-4 [17:20]
Sorry that it's hard for us to compare thouand of parts of those 2 components.
It needs to be checked in the factory side.
Thanks.
2016-8-4 [12:02]
The reseller I bought as closed , there is no way i can contact them , please could you help me with some pcb pictures to compare my card , to check where are missing those
2016-8-4 [11:15]
Dear Sir:
Please prepare card's receipt or invoice then contact reseller where you purchased the card for claim RMA service again.
2016-8-4 [08:02]
Hi , I wanted some help from you guys , so I shiped my GPU and in the shipping some SMD condenser's appeard in the box flying away and I cannot find any high resolution picture of the pcb to know where are them from , I will leave some pic's of what happened. I hope you guys can help me
