Two SFF builds I am considering
Hey, I'm kind of new to the community (been subbed on youtube for ages). I recently moved room in my house and I dont have alot of space for a ATX sized PC, or more precisely I need to save space as this room is also my studio (I am a painter when I am not playing games) so I have opted to go for the smaller form factor.
I've read lots of stuff about the fractal node 304, and it just seems the right size, theres a perfect little place in my room for a case of this size that would mean it isn't in the way like my current tower pc is.
Currently I have this build for higher end gaming:
http://uk.pcpartpicker.com/p/2nVyI
and this for a cheaper steamOS/linux box (I am a old linux user, I know linux pretty well) with an intention to put the Kaveri APU in it in the future (if it really turns out to be as interesting as they sound):
http://uk.pcpartpicker.com/p/2nIiA
All I need is the parts checking over and any advice on motherboards in this form factor, I am alright with assembling PCs I am just new to the mITX form factor.
trying to keep the budget under £1000 for both.
What distro do you run day-to-day, man?
Anyhoo, the biggest thing I'd change is drop that 760 4GB to a 760 2GB or 280X (don't know about pricing or availability anymore due to the LTC explosion).
For the longest time I was a mandrake/mandriva user then gentoo, then I kind of simplified and ended up with Kubuntu, which I have stuck with (as I prefer the KDE environment) scince.
Ok, thank you!I
a big question that is bugging me is have I got the PSU sizes right in both?
Well, quality-wise, they aren't that nice (Integra uses HEC, Corsair uses CWT - both pretty eh, rather low-end), but wattage-wise, they are perfect, if not oversized (which is fine at that low of a wattage).
I wouldn't personally use those PSUs (due to their efficiency and build quality) in my own rig, but if you aren't pushing them much (you aren't), I don't see why not if you're getting a good deal.
However, if you can find it for a decent price, the Seasonic G 550 in both systems would be ideal. High efficiency, low ripple, semi-modular, and very nice unit.
That seems fine for my budget...
Then grab it; the Seasonic G is much better internally - higher efficiency, cleaner rails, lower ripple, and much better warranty (that FD unit only has a 1 year).
thanks for the help!
