Two GTX 670 went bad at same time?
I had two EVGA GTX 670s in SLI and one day while playing a game my computer would just immediately restart on me. I took one card out and ran the other as a single card for a while and things worked and then one day shortly after the same thing happened again. My computer would just up and restart while in a game.
What is odd to me is if I watched the temps they were fine, not overheating. I could run Furmark for a 15min stress test with no problem. I could run Prime95 and Memtest (forget the software name) with no errors or problems. The processor temps were well within a good operating temperature. If I ran a game though, the computer restarted.
When I say the computer restarted, it wasn't a blue screen, no warning of you need to restart, just an immediate no warning restart. I could surf the web or youtube all day long with no problem. I could load a game and it would last an hour or 10min and restart. Just odd to me.
I ended up putting another EVGA 550 Ti in that I had and so far I have played a few games with no problems.
Is it just that I have two cards that went bad at the same time or could there be some other problem I haven't discovered that you guys might have ideas of? I just worry that something else could be a cause of my card failure and I want to know because I want to get a EVGA 780 Ti hopefully soon.
Thanks
What psu - make/model are you using?
If you are able to test the 670's in another system that would be ideal just to rule them out.
I very much doubt they are dead as to lose 2 at the same time is beyond bad luck.
The PSU is Corsair HX750. It is around 2.5 years old now. The whole computer is really.
BTW I didn't run them overclocked. Everything was stock.
I am a processor shy of having a test bench setup that I can test on but I will just have to hold on to them until then. I just put the cards on the shelf for now until I can do like you said and test them before completely getting rid of them.
