I already have a computer built, but am wondering how to max out it with my other build. My other build, being my old one from 2009/10.
Here is the run down. Currently I am running my rig with these components.
Case: Corsair Graphite 600t
Mobo: Asus Sabertooth 990FX
CPU: AMD FX 8320
RAM: 16gb 4 * 4gb Corsair Vengance 1600
GPU: XFX AMD Radeon R9 280x
Drives: 120gb Mushkin SSD, Intel 330 240gb (used solely as gaming drive), 2TB Seagate, LG Bluray
Cooling: Corsair H80i
Sound Card: Soundblast Recon 3d
Build 2 (Possible, already have all the components, I just want to know what I should mismatch from both)
Case: Corsair Carbide Air 540
Mobo: ASrock MATX (shitty, not sure what it is, but supports AM3, 40 dollars or so)
CPU: Phenom II X6 1090t
RAM: 8GB Patriot 1600
GPU: EVGA GTX 580 SC
Drives: 2 x 240gb PNY Optima (possibly raId?), 2 x 1TB WD (one blue on black), 320GB WD (for games?, pulled it out of a old laptop that was being thrown away), LG DVD burner
I think for the most part the builds are good. I was gonna make number 2 be my htpc/audio controller. Problem is, the mobo doesn't even support 5.1. I was thinking, the sabertooth already has decent audio onboard, I would pop the recon 3d in the second build? It would allow me to hook my surround sound system up and have my tv, consoles, dvr, etc all controlled by the pc (one output source). I am thinking about making one of these into a home cloud server too. Not sure which one, plan on one being used for LAN parties. At the same time the server has to be on 24/7, which means I might use the audio controller one as that. I am not sure.
What I want out of this is:
One that controls all of my electronic audio
One that acts as a cloud/home storage pc
One for Virtualware (vBox. vmware)
Operating System can be 8.1 or 7
Both have to have good AV, I am thinking the server would be used as a firewall of sorts. Have all traffic routed through it via a second nic and then scanned with two different AV. I am thinking my primary gaming one is going to use Avast and the secondary is AVG or something.
So one rig is going to be for gaming, word processing, everyday use. The second is just going to tie all my audio from my toys through to my speaker system. The audio one would probably be better to act as a cloud server. I plan on using this for family and friend use (the cloud). I was gonna start with 2tb, and use my external as a backup of that. Also the HTPC will probably make use of a lot of emulators/roms, as I love pokemon on my tv. I am pretty sure I know what I want, but I wish for your advice. All of the parts for these two builds are interchangeable, but I need to know which ram I should be putting in for which. I assume the 16gb should be swapped out for 8gb, because 16gb is more beneficial for the server. However I am not sure. Both have 400-600 dollar cards, 6 and 8 core cpus, both will have two ssds and a large volume of hdd space.
