aszure
April 15, 2013, 12:37am
1
i have nzxt hale82 850w power and im planning to buy one 7970 for now. when i buy my second card, can the psu handle it? or would i need to buy a better psu?
here is myother components:
AMD FX-8320
ASUS M5A99X Evo R2.0
8gb ram
128 gb ssd
2 tb hdd
h100 cpu cooler
As long as you don't UBER clock your cpu, and both gpus. they should be fine.
Z11
April 15, 2013, 12:41am
3
It's more than enough IMO. The least amount of wattage I'd use in this situation is 750W
Even with UBER clocks, that would be fine. People usually have a good 100-300W of unused power. Like me, running a single 680 4GB on an 850W PSU.
Like others have said, totally fine. You will be able to overclock your system quiet a bit.
aszure
April 15, 2013, 5:15am
6
uberclock meaning 200mhz or more right?
Uberclocking; you could take those 7970s to 1500mHz/7000mHz with a 6.0gHz CPU on an 850W PSU.
you could probably do that on a decent 750Watt PSU, 850 should be fine.
