Tweaks for my first build?
http://pcpartpicker.com/user/KobeTevaga/saved/2dqC
This is my first build. I was wondering if there is anything I should change. It would be great if the computer stayed in the $500-$600 range but if we have to raise it to $700 that would be fine. This is my first build so it would be much appreciated.
http://pcpartpicker.com/p/1unNF
FM2 boards are better for APU builds.
AM3+ boards are better for cpu and gpu combo.
The reason is AM3+ boards have better upgrade paths.
you are fine but you would need a new motherboard to upgrade your cpu
Go for Tmlhalo's Build, it looks like a great option for your pice range.
If you want to overclock straight away or later on, get the Asus M5A99FX Pro R2.0 Motherboard. It's 135 dollars ATM, but it's such a good MoBo! If you don't you can stick with this one, also a good choise!
