I would like to build a high storage/performance using all hdd drive bays with cheaper/higher storage platter HDDs for LAN streaming/media storage, eventually being able to have at least 8 TB data 8 TB back up, which RAID setup will manage this setup the best? Do you recommend PCIe or built in motherboard RAID controller? I eventually want to use it for gaming with a steam controller as well, let me Know what you think of what this build any recommendations, suggestions and threats?
1 Antec Twelve Hundred V3 Black Steel ATX Full Tower Unbeatable Gaming Case $164.99
1 GIGABYTE GA-X79-UP4 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard $239.99
1 XFX Core Edition FX-785A-CNL4 Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card $189.99
1 Thermaltake TR2 TR-700 700W ATX 12V V2.3 & EPS 12V SLI Ready CrossFire Ready Active PFC Power Supply $69.99
1 Intel Core i7-3820 Sandy Bridge-E 3.6GHz (3.8GHz Turbo Boost) LGA 2011 130W Quad-Core Desktop Processor $299.99
1 G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model $76.99
1 Manufacturer Recertified Corsair Force CSSD-F115GB2-A/RF2 2.5" 115GB SATA II MLC Internal Solid State Drive (SSD) $59.99
2 TOSHIBA DT01ACA300 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive $239.98 (Was planing on getting 2 4TB drives later on)
Total $1,341.91 (all prices from new egg if you know a cheaper spot to get any of it) I want this build to have lots of room to expand and be powerful enough to do photoshop, gaming and high rendering for around the 1300 to 1500 dollar price.
