Is there a guide on how to rebind the sniper DPI slowdown button to be a extra button on the mouse?
I have head suggestions to use the sniper button as a push to talk button.
I have one and I'm not sure if it's possible. I think it may be a hardware level switch in the mouse solely to bring the DPI down.
my corsair m65 can, in the software package
I agree with @Zeta, it seems to be a hardware level switch that adjusts the DPI down to 500 and can't be assigned by the OS.
I believe this is correct.
I'm surprised you didn't light it on fire. Good four you.
Look for a Serial Connection Reader and just rebind the hardware. Should be good to go afterwards. Make it F24 or something.
Any recommendations for which software to use?
They all do the same thing. I just found one on Softpedia when I was doing BIOS shit.
What do I look up to get guides?
Because I found software, but I can't find any guides specific to what I am trying to do
It should be just as quick as scanning the thing and finding the ID of the key itself and re-writing it. What that ID is I dunno. There should be a way to check that but I don't really know how.
What is the action of that called?
I dunno you're in the app I'll assume you can figure it out. I'm not at your desk. All I can say is good luck.
