I meant the dll overrides tab, for what ever reason that seemed to get it to launch using the built in
override.
The issue I was getting earlier
was solved by using the overide dlls. I tested it again without the native dlls, and it seemed to throw the same quoted error
I also used a download from a different link from the admin link
https://admin.microsoft.com/account#home
The issue now is figuring out the error outputs
002c:fixme:winediag:start_process Wine Staging 5.15 is a testing version containing experimental patches.
002c:fixme:winediag:start_process Please mention your exact version when filing bug reports on winehq.org.
00ac:fixme:ntdll:EtwEventRegister ({8736922d-e8b2-47eb-8564-23e77e728cf3}, 005FB79C, 00AB0550, 00AB0550) stub.
00ac:fixme:ntdll:EtwEventSetInformation (deadbeef, 0, 00000000, 0) stub
00ac:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031FD8C 1 C) semi-stub
00ac:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031FDA8 1 C) semi-stub
00ac:fixme:ole:CoInitializeSecurity 00000000, -1, 00000000, 00000000, 0, 3, 00000000, 0, 00000000 stub
00ac:fixme:ntdll:EtwEventRegister ({a019725f-cff1-47e8-8c9e-8fe2635b6388}, 005FB79C, 00AB2B10, 00AB2B10) stub.
00ac:fixme:ntdll:EtwEventRegister ({f50d9315-e17e-43c1-8370-3edf6cc057be}, 006AE6FA, 00AB2AD8, 00AB2AD8) stub.
00ac:fixme:ntdll:EtwEventRegister ({e6aec961-a5e0-5560-a860-15edd6b70f6c}, 004A4243, 00AB0518, 00AB0530) stub.
00ac:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 0097A2B1, 56) stub
00ac:fixme:ntdll:EtwEventUnregister (deadbeef) stub.
00ac:fixme:ver:GetCurrentPackageId (0031F518 00000000): stub
00ac:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031EFC8 1 C) semi-stub
00ac:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031EE78 1 C) semi-stub
00ac:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031EE18 1 C) semi-stub
00ac:fixme:msi:open_userdata_comp_key only looking at the current user
00ac:fixme:nls:get_dummy_preferred_ui_language (0x8 0031F130 00000000 0031F12C) returning a dummy value (current locale)
00ac:fixme:nls:get_dummy_preferred_ui_language (0x8 0031F130 00ADAB38 0031F12C) returning a dummy value (current locale)
00ac:fixme:ntdll:EtwEventRegister ({559a5658-8100-4d84-b756-0a47a476280c}, 005FB79C, 00AB2AA0, 00AB2AA0) stub.
00ac:fixme:ntdll:EtwEventRegister ({02fd33df-f746-4a10-93a0-2bc6273bc8e4}, 005FB79C, 00ACEF88, 00AE59C8) stub.
00b0:fixme:xmllite:xmlreader_SetProperty Unimplemented property (18)
00ac:fixme:sync:SetWaitableTimerEx (000000A4, 0031F4D0, 0, 00000000, 00000000, 00000000, 7644570) semi-stub
00b0:fixme:ver:GetFileVersionInfoSizeExW flags 0x2 ignored
00b0:fixme:ver:GetFileVersionInfoExW flags 0x2 ignored
00c4:fixme:netapi32:NetGetJoinInformation Semi-stub (null) 0x219ee94 0x219ee90
00c4:fixme:reg:NtSetInformationKey (0x150,0x00000002,0x219e8e0,0x00000004) stub
00c4:fixme:ntdll:EtwEventRegister ({8736922d-e8b2-47eb-8564-23e77e728cf3}, 0233B6FA, 0255B1A8, 0255B1A8) stub.
00c4:fixme:ntdll:EtwEventSetInformation (deadbeef, 0, 00000000, 0) stub
00c4:fixme:rpc:RpcServerRegisterIf3 Unsupported SecurityDescriptor argument.
00c4:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0219E46C 1 C) semi-stub
00c4:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0219E31C 1 C) semi-stub
00d8:fixme:netprofm:list_manager_QueryInterface interface {e19c7100-9709-4db7-9373-e7b518b47086} not implemented
00d8:fixme:netprofm:connection_point_Advise 01208030, 00F55368, 02E3FB24 - semi-stub
0024:fixme:ntdll:EtwEventRegister ({8736922d-e8b2-47eb-8564-23e77e728cf3}, 00465574, 008316E8, 008316E8) stub.
0024:fixme:ntdll:EtwEventSetInformation (deadbeef, 0, 00000000, 0) stub
0024:fixme:ole:CoInitializeSecurity 00000000, -1, 00000000, 00000000, 0, 3, 00000000, 0, 00000000 stub
0024:fixme:ntdll:EtwEventRegister ({a019725f-cff1-47e8-8c9e-8fe2635b6388}, 00465574, 008318A8, 008318A8) stub.
0024:fixme:ntdll:EtwEventRegister ({f50d9315-e17e-43c1-8370-3edf6cc057be}, 00524AAB, 00831720, 00831720) stub.
0024:fixme:ntdll:EtwEventRegister ({e6aec961-a5e0-5560-a860-15edd6b70f6c}, 00401000, 008317C0, 008317D8) stub.
0024:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 007E5359, 56) stub
0024:fixme:ntdll:EtwEventUnregister (deadbeef) stub.
0024:fixme:ver:GetCurrentPackageId (0031EEDC 00000000): stub
0024:fixme:msi:open_userdata_comp_key only looking at the current user
0024:fixme:nls:get_dummy_preferred_ui_language (0x8 0031EAE0 00000000 0031EADC) returning a dummy value (current locale)
0024:fixme:nls:get_dummy_preferred_ui_language (0x8 0031EAE0 008506B8 0031EADC) returning a dummy value (current locale)
0024:fixme:ntdll:EtwEventRegister ({559a5658-8100-4d84-b756-0a47a476280c}, 00465574, 00831780, 00831780) stub.
0024:fixme:ntdll:EtwEventRegister ({02fd33df-f746-4a10-93a0-2bc6273bc8e4}, 00465574, 00832038, 00850B08) stub.
0024:fixme:sync:SetWaitableTimerEx (000000B8, 0031EEF8, 0, 00000000, 00000000, 00000000, 7644570) semi-stub
00f0:fixme:ver:GetFileVersionInfoSizeExW flags 0x2 ignored
00f0:fixme:ver:GetFileVersionInfoExW flags 0x2 ignored
00f0:fixme:xmllite:xmlreader_SetProperty Unimplemented property (18)
0024:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0024:fixme:exec:SHELL_execute flags ignored: 0x00000100
010c:fixme:powershell:wmain stub: L"C:\\windows\\system32\\WindowsPowershell\\v1.0\\powershell.exe" L"-NoProfile" L"$package = Get-AppxPackage Microsoft.Office.Desktop -allUsers; if (!$package) { $Error.Add(\"Package is not installed\")}; if ($error.Count -eq 0) { Out-File -FilePath 'C:\\users\\bedhedd\\Temp\\Office.ValidateResult.scratch' -InputObject '1' -Encoding ascii; } else { Out-File -FilePath '"...
011c:fixme:powershell:wmain stub: L"C:\\windows\\system32\\WindowsPowershell\\v1.0\\powershell.exe" L"-NoProfile" L"$package = Get-AppxPackage Microsoft.Office.Desktop -allUsers; if (!$package) { $Error.Add(\"Package is not installed\")}; if ($error.Count -eq 0) { Out-File -FilePath 'C:\\users\\bedhedd\\Temp\\Office.ValidateResult.scratch' -InputObject '1' -Encoding ascii; } else { Out-File -FilePath '"...
0024:fixme:ole:CoEnableCallCancellation (00000000): stub
0024:err:ole:create_server class {5b99fa76-721c-423c-adac-56d03c8a8007} not registered
0024:err:ole:CoGetClassObject no class object {5b99fa76-721c-423c-adac-56d03c8a8007} could be created for context 0x4
00f8:fixme:powrprof:PowerDeterminePlatformRole stub
0060:fixme:mountmgr:query_property Unsupported property 0x7
00f8:fixme:ntdll:NtQuerySystemInformation (0x000000c9,0x1aff718,0x00000004,(nil)) stub
00f8:fixme:bcrypt:BCryptCreateHash ignoring object buffer
0024:fixme:wintrust:SOFTPUB_VerifyImageHash Cannot verify hash for pszObjId="1.3.6.1.4.1.311.2.1.28"
0024:fixme:urlmon:SecManagerImpl_ProcessUrlAction Unsupported arguments
0024:fixme:iphlpapi:CreateSortedAddressPairs (src_list (nil) src_count 0 dst_list 0x15cec20 dst_count 9 options 0 pair_list 0x31e020 pair_count 0x31e018): stub
0024:fixme:iphlpapi:CreateSortedAddressPairs only mapped IPv4 addresses are supported
0140:fixme:ntdll:EtwEventRegister ({8736922d-e8b2-47eb-8564-23e77e728cf3}, 005FB79C, 00AB0550, 00AB0550) stub.
0140:fixme:ntdll:EtwEventSetInformation (deadbeef, 0, 00000000, 0) stub
0140:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031FD8C 1 C) semi-stub
0140:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031FDA8 1 C) semi-stub
0140:fixme:ole:CoInitializeSecurity 00000000, -1, 00000000, 00000000, 0, 3, 00000000, 0, 00000000 stub
0140:fixme:ntdll:EtwEventRegister ({a019725f-cff1-47e8-8c9e-8fe2635b6388}, 005FB79C, 00AB2B10, 00AB2B10) stub.
0140:fixme:ntdll:EtwEventRegister ({f50d9315-e17e-43c1-8370-3edf6cc057be}, 006AE6FA, 00AB2AD8, 00AB2AD8) stub.
0140:fixme:ntdll:EtwEventRegister ({e6aec961-a5e0-5560-a860-15edd6b70f6c}, 004A4243, 00AB0518, 00AB0530) stub.
0140:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 0097A2B1, 56) stub
0140:fixme:ntdll:EtwEventUnregister (deadbeef) stub.
0140:fixme:ver:GetCurrentPackageId (0031F518 00000000): stub
0140:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031EFC8 1 C) semi-stub
0140:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031EE78 1 C) semi-stub
0140:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031EE18 1 C) semi-stub
0140:fixme:msi:open_userdata_comp_key only looking at the current user
0140:fixme:nls:get_dummy_preferred_ui_language (0x8 0031F130 00000000 0031F12C) returning a dummy value (current locale)
0140:fixme:nls:get_dummy_preferred_ui_language (0x8 0031F130 00ADAB38 0031F12C) returning a dummy value (current locale)
0140:fixme:ntdll:EtwEventRegister ({559a5658-8100-4d84-b756-0a47a476280c}, 005FB79C, 00AB2AA0, 00AB2AA0) stub.
0140:fixme:ntdll:EtwEventRegister ({02fd33df-f746-4a10-93a0-2bc6273bc8e4}, 005FB79C, 00ACEF88, 00AE59C8) stub.
0140:fixme:sync:SetWaitableTimerEx (000000BC, 0031F4D0, 0, 00000000, 00000000, 00000000, 7644070) semi-stub
0144:fixme:xmllite:xmlreader_SetProperty Unimplemented property (18)
0144:fixme:ver:GetFileVersionInfoSizeExW flags 0x2 ignored
0144:fixme:ver:GetFileVersionInfoExW flags 0x2 ignored
0140:fixme:reg:NtSetInformationKey (0x148,0x00000002,0x31ebf0,0x00000004) stub
0140:fixme:rpc:RpcServerRegisterIf3 Unsupported SecurityDescriptor argument.
0160:fixme:ntdll:EtwEventRegister ({8736922d-e8b2-47eb-8564-23e77e728cf3}, 02310FBD, 0244A220, 0244A220) stub.
0160:fixme:ntdll:EtwEventSetInformation (deadbeef, 0, 00000000, 0) stub
0160:fixme:ver:GetCurrentPackageId (022AE8C0 00000000): stub
0160:fixme:nls:get_dummy_preferred_ui_language (0x8 022AE81C 00000000 022AE818) returning a dummy value (current locale)
0160:fixme:nls:get_dummy_preferred_ui_language (0x8 022AE81C 02453E70 022AE818) returning a dummy value (current locale)
0050:fixme:appbar:handle_appbarmessage SHAppBarMessage(ABM_GETTASKBARPOS, hwnd=00000000): stub
0170:fixme:ole:NdrCorrelationInitialize (0270E56C, 0270E058, 1024, 0x0): semi-stub
0178:fixme:ole:NdrCorrelationInitialize (0327F818, 0327F8F4, 1024, 0x0): semi-stub
0178:fixme:ole:NdrCorrelationFree (0327F818): stub
0170:fixme:ole:NdrCorrelationFree (0270E56C): stub
0180:err:ole:COMPOBJ_DllList_Add couldn't load in-process dll L"C:\\Program Files\\Common Files\\Microsoft Shared\\ClickToRun\\msoxmlmf.dll"
0050:fixme:explorer:webbrowser_QueryInterface (0041E20C)->({00000003-0000-0000-c000-000000000046} 0069E7EC) interface not supported
0050:fixme:explorer:webbrowser_QueryInterface (0041E20C)->({00000003-0000-0000-c000-000000000046} 0069E754) interface not supported
0050:fixme:explorer:webbrowser_QueryInterface (0041E20C)->({00000019-0000-0000-c000-000000000046} 00AB9A20) interface not supported
01b8:fixme:ntdll:EtwEventRegister ({8736922d-e8b2-47eb-8564-23e77e728cf3}, 00499985, 0116B170, 0116B170) stub.
01b8:fixme:ntdll:EtwEventSetInformation (deadbeef, 0, 00000000, 0) stub
01b8:fixme:ntdll:EtwEventRegister ({a019725f-cff1-47e8-8c9e-8fe2635b6388}, 00499985, 0116B080, 0116B080) stub.
01b8:fixme:ntdll:EtwEventRegister ({f50d9315-e17e-43c1-8370-3edf6cc057be}, 006C39F9, 0116B1A8, 0116B1A8) stub.
01b8:fixme:ntdll:EtwEventRegister ({e6aec961-a5e0-5560-a860-15edd6b70f6c}, 00401000, 0116B040, 0116B058) stub.
01b8:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 010CAA49, 56) stub
01b8:fixme:ntdll:EtwEventUnregister (deadbeef) stub.
01b8:fixme:ver:GetCurrentPackageId (0031F858 00000000): stub
01b8:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031F328 1 C) semi-stub
01b8:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031F1D8 1 C) semi-stub
01b8:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031F178 1 C) semi-stub
01b8:fixme:d2d:d2d_factory_init Ignoring factory type 0x1.
01b8:fixme:wtsapi:WTSRegisterSessionNotification Stub 000100B0 0x00000000
01b8:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
01b8:fixme:system:GetDisplayConfigBufferSizes (0x2 0x31f5d8 0x31f5d4): semi-stub
01b8:fixme:msi:open_userdata_comp_key only looking at the current user
01b8:fixme:nls:get_dummy_preferred_ui_language (0x8 0031F464 00000000 0031F460) returning a dummy value (current locale)
01b8:fixme:nls:get_dummy_preferred_ui_language (0x8 0031F464 011AE668 0031F460) returning a dummy value (current locale)
01b8:fixme:seh:WerRegisterFile (L"C:\\users\\bedhedd\\Temp\\{C1240C82-13A3-4A0A-BDA4-FDC5068DC9D4} - OProcSessId.dat", 2, 3) stub
01b8:fixme:ntdll:EtwEventRegister ({559a5658-8100-4d84-b756-0a47a476280c}, 00499985, 0116AFF8, 0116AFF8) stub.
01b8:fixme:ntdll:EtwEventRegister ({02fd33df-f746-4a10-93a0-2bc6273bc8e4}, 00499985, 0116B500, 011ADD08) stub.
01b8:fixme:sync:SetWaitableTimerEx (000000C4, 0031F85C, 0, 00000000, 00000000, 00000000, 7643820) semi-stub
027c:fixme:xmllite:xmlreader_SetProperty Unimplemented property (18)
027c:fixme:ver:GetFileVersionInfoSizeExW flags 0x2 ignored
027c:fixme:ver:GetFileVersionInfoExW flags 0x2 ignored
027c:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (04DAF248 1 C) semi-stub
01b8:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0031F394 1 C) semi-stub
01b8:fixme:ntdll:EtwEventRegister ({8736922d-e8b2-47eb-8564-23e77e728cf3}, 05030FBD, 0516A220, 0516A220) stub.
01b8:fixme:htmlhelp:HtmlHelpW HH case HH_INITIALIZE not handled.
01b8:fixme:ntdll:EtwEventRegister ({f562bb8e-422d-4b5c-b20e-90d710f7d11c}, 00499985, 01170448, 01170448) stub.
01b8:fixme:ntdll:EtwEventRegister ({b4f150b4-67db-4742-8846-2cd7b16ee60e}, 00499985, 0116E3C0, 0116E3C0) stub.
01b8:fixme:win:RegisterPointerDeviceNotifications (0x100c2 0): stub
01b8:fixme:wtsapi:WTSRegisterSessionNotificationEx Stub 00000000 000100C2 0x00000000
01b8:fixme:ver:GetCurrentPackageId (0031EDB8 00000000): stub
01b8:fixme:nls:get_dummy_preferred_ui_language (0x8 0031ED14 00000000 0031ED10) returning a dummy value (current locale)
01b8:fixme:nls:get_dummy_preferred_ui_language (0x8 0031ED14 05173E70 0031ED10) returning a dummy value (current locale)
01b8:fixme:win:RegisterTouchHitTestingWindow (0x100ce 1): stub
0294:fixme:combase:RoGetActivationFactory (L"Windows.Security.Isolation.IsolatedWindowsEnvironmentHost", {2c0e22c7-05a0-517a-b81c-6ee8790c381f}, 02E3E9BC): semi-stub
0294:err:combase:RoGetActivationFactory Failed to find library for L"Windows.Security.Isolation.IsolatedWindowsEnvironmentHost"
0294:fixme:combase:GetRestrictedErrorInfo (02E3E964)
0294:fixme:combase:RoOriginateLanguageException (80040150 L"" 00000000) stub
01b8:fixme:richedit:REExtendedRegisterClass semi stub
01b8:fixme:richedit:ME_HandleMessage EM_SETEDITSTYLE: stub
01b8:fixme:richedit:ME_HandleMessage EM_GETLANGOPTIONS: stub
01b8:fixme:richedit:ME_HandleMessage EM_SETBIDIOPTIONS: stub
01b8:fixme:msctf:SetInputScope STUB: 000100DC 0
0298:fixme:dxgi:DXGID3D10CreateDevice Ignoring flags 0x20.
0298:fixme:d3d11:d3d11_device_CheckFeatureSupport Returning fake Options support data.
02a8:fixme:ntdll:EtwEventProviderEnabled deadbeef, 4, 2: stub
01b8:fixme:dxgi:DXGID3D10CreateDevice Ignoring flags 0x30.
0298:fixme:ntdll:EtwEventProviderEnabled deadbeef, 4, 2: stub
01b8:fixme:win:RegisterTouchHitTestingWindow (0x100e0 1): stub
01b8:fixme:msctf:SetInputScope STUB: 000100E8 0
01b8:fixme:ole:NdrCorrelationInitialize (0031E1E0, 0031DCCC, 1024, 0x0): semi-stub
01b8:fixme:ole:NdrCorrelationFree (0031E1E0): stub
02a0:fixme:ntdll:EtwEventRegister ({8736922d-e8b2-47eb-8564-23e77e728cf3}, 0042490A, 007CCCB0, 007CCCB0) stub.
02a0:fixme:ntdll:EtwEventSetInformation (deadbeef, 0, 00000000, 0) stub
01b8:fixme:explorerframe:taskbar_list_SetProgressState iface 02ACFB38, hwnd 000300D4, flags 1 stub!
01b8:fixme:win:IsWindowRedirectedForPrint (0x100e0): stub
01b8:fixme:win:IsWindowRedirectedForPrint (0x200de): stub
01b8:fixme:win:IsWindowRedirectedForPrint (0x300d4): stub
01b8:fixme:win:IsWindowRedirectedForPrint (0x100ca): stub
02a8:fixme:dxgi:wined3d_swapchain_desc_from_dxgi Ignoring scaling 0x1.
02a8:fixme:dxgi:wined3d_swapchain_desc_from_dxgi Ignoring alpha mode 0.
02a8:fixme:d3d:wined3d_swapchain_init The application requested more than one back buffer, this is not properly supported.
Please configure the application to use double buffering (1 back buffer) if possible.
02a8:fixme:d3d:wined3d_swapchain_init Unimplemented swap effect 0x3.
02a8:fixme:dxgi:d3d11_swapchain_GetDesc Ignoring ScanlineOrdering and Scaling.
02a8:fixme:dxgi:d3d11_swapchain_SetBackgroundColor iface 0x2a39c68, color 0x5b9fc18 stub!
02a8:fixme:d3d11:d3d11_immediate_context_DiscardView1 iface 028163B0, view 02AD35F0, rects 05B9FC88, num_rects 1 stub!
02a4:fixme:d3d:state_linepattern_w Setting line patterns is not supported in OpenGL core contexts.
02a8:fixme:dwmapi:DwmIsCompositionEnabled 05B9FCEC
02a0:fixme:ntdll:EtwEventRegister ({a019725f-cff1-47e8-8c9e-8fe2635b6388}, 0042490A, 007CD7C0, 007CD7C0) stub.
02a0:fixme:ntdll:EtwEventRegister ({f50d9315-e17e-43c1-8370-3edf6cc057be}, 00455003, 007CCCE8, 007CCCE8) stub.
02a0:fixme:ntdll:EtwEventRegister ({e6aec961-a5e0-5560-a860-15edd6b70f6c}, 00401000, 007CD780, 007CD798) stub.
02a0:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 007983B1, 56) stub
02a0:fixme:ntdll:EtwEventUnregister (deadbeef) stub.
02a0:fixme:ver:GetCurrentPackageId (0031F590 00000000): stub
02a0:fixme:msi:open_userdata_comp_key only looking at the current user
02a0:fixme:ntdll:EtwEventRegister ({559a5658-8100-4d84-b756-0a47a476280c}, 0042490A, 007CEF00, 007CEF00) stub.
02a0:fixme:ntdll:EtwEventRegister ({02fd33df-f746-4a10-93a0-2bc6273bc8e4}, 0042490A, 007CEFE8, 007E5AC8) stub.
02a0:fixme:sync:SetWaitableTimerEx (0000008C, 0031F840, 0, 00000000, 00000000, 00000000, 1320) semi-stub
02b4:fixme:ver:GetFileVersionInfoSizeExW flags 0x2 ignored
02b4:fixme:ver:GetFileVersionInfoExW flags 0x2 ignored
02b4:fixme:xmllite:xmlreader_SetProperty Unimplemented property (18)
02a0:fixme:urlmon:SecManagerImpl_ProcessUrlAction Unsupported arguments
01c0:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (02D1FA6C 1 C) semi-stub
01c0:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (02D1FA9C 1 C) semi-stub
0318:fixme:combase:RoGetActivationFactory (L"Windows.Networking.Connectivity.NetworkInformation", {5074f851-950d-4165-9c15-365619481eea}, 03C144BC): semi-stub
0318:err:combase:RoGetActivationFactory Failed to find library for L"Windows.Networking.Connectivity.NetworkInformation"
00b4:fixme:win:RegisterPowerSettingNotification (0x10030,{245d8541-3943-4422-b025-13a784f679b7},0): stub
00b4:fixme:win:RegisterPowerSettingNotification (0x10030,{5d3e9a59-e9d5-4b00-a6bd-ff34ff516548},0): stub
00b4:fixme:win:RegisterPowerSettingNotification (0x10030,{a7ad8041-b45a-4cae-87a3-eecbb468a9e1},0): stub
00b4:fixme:win:RegisterPowerSettingNotification (0x10030,{98a7f580-01f7-48aa-9c0f-44352c29e5c0},0): stub
00b4:fixme:win:RegisterPowerSettingNotification (0x10030,{02731015-4510-4526-99e6-e5a17ebd1aea},0): stub
00b4:fixme:win:RegisterPowerSettingNotification (0x10030,{3c0f4548-c03f-4c4d-b9f2-237ede686376},0): stub
01b8:fixme:explorerframe:taskbar_list_SetProgressValue iface 02ACFB38, hwnd 000300D4, ullCompleted 3a, ullTotal 64 stub!
02a8:fixme:dxgi:d3d11_swapchain_Present1 Ignored present parameters 0x5b9fcf8.
00b8:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (01F7EF28 1 C) semi-stub
00b8:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (01F7EF88 1 C) semi-stub
00b8:fixme:file:NtLockFile I/O completion on lock not implemented yet
00b8:fixme:combase:RoGetActivationFactory (L"Windows.Security.Authentication.OnlineId.OnlineIdSystemAuthenticator", {85047792-f634-41e3-96a4-5164e902c740}, 01F7F2C4): semi-stub
00b8:err:combase:RoGetActivationFactory Failed to find library for L"Windows.Security.Authentication.OnlineId.OnlineIdSystemAuthenticator"
00b8:fixme:reg:NtQueryLicenseValue License key L"Microsoft-Windows-Container-License-Mode" not found
00f4:fixme:win:RegisterPowerSettingNotification (0x10070,{245d8541-3943-4422-b025-13a784f679b7},0): stub
00f4:fixme:win:RegisterPowerSettingNotification (0x10070,{5d3e9a59-e9d5-4b00-a6bd-ff34ff516548},0): stub
00f4:fixme:win:RegisterPowerSettingNotification (0x10070,{a7ad8041-b45a-4cae-87a3-eecbb468a9e1},0): stub
00f4:fixme:win:RegisterPowerSettingNotification (0x10070,{98a7f580-01f7-48aa-9c0f-44352c29e5c0},0): stub
00f4:fixme:win:RegisterPowerSettingNotification (0x10070,{02731015-4510-4526-99e6-e5a17ebd1aea},0): stub
00f4:fixme:win:RegisterPowerSettingNotification (0x10070,{3c0f4548-c03f-4c4d-b9f2-237ede686376},0): stub
036c:fixme:winspool:UploadPrinterDriverPackageW (null), L"C:\\Program Files\\Microsoft Office\\root\\Office16\\OneNote\\\\prnms006.inf", (null), 1, 0x10020, 0x19ff538, 0x19ff534
036c:fixme:winspool:UploadPrinterDriverPackageW (null), L"C:\\Program Files\\Microsoft Office\\root\\Office16\\OneNote\\\\prnSendToOneNote_Win7.inf", (null), 1, 0x10020, 0x19ff538, 0x19ff534
0370:fixme:hnetcfg:fwpolicy2_get_CurrentProfileTypes 0173F568 01B0F63C
0370:fixme:hnetcfg:fwpolicy2_get_CurrentProfileTypes 01802BB8 01B0FAA0
0370:fixme:hnetcfg:fwpolicy2_get_CurrentProfileTypes 017453C8 01B0F63C
0370:fixme:hnetcfg:fwpolicy2_get_CurrentProfileTypes 0173D3A8 01B0FAA0
0370:fixme:hnetcfg:fwpolicy2_get_CurrentProfileTypes 01749540 01B0FAA0
0370:fixme:hnetcfg:fwpolicy2_get_CurrentProfileTypes 01740208 01B0FAA0
0380:fixme:propsys:PSRegisterPropertySchema L"C:\\Program Files\\Microsoft Office\\root\\Office16\\Custom.propdesc" stub
0398:fixme:wevtutil:wmain stub: L"wevtutil.exe" L"im" L"C:\\ProgramData\\Microsoft\\ClickToRun\\{9AC08E99-230B-47e8-9721-4577B7F124EA}\\wordEtw.man" L"/rf:C:\\Program Files\\Microsoft Office\\root\\Office16\\wwlib.dll" L"/mf:C:\\Program Files\\Microsoft Office\\root\\Office16\\wwlib.dll"
03a0:fixme:wevtutil:wmain stub: L"wevtutil.exe" L"im" L"C:\\ProgramData\\Microsoft\\ClickToRun\\{9AC08E99-230B-47e8-9721-4577B7F124EA}\\msoutilstat.etw.man" L"/rf:C:\\Program Files\\Microsoft Office\\root\\Office16\\msoetwres.dll" L"/mf:C:\\Program Files\\Microsoft Office\\root\\Office16\\msoetwres.dll"
03a8:fixme:wevtutil:wmain stub: L"wevtutil.exe" L"im" L"C:\\ProgramData\\Microsoft\\ClickToRun\\{9AC08E99-230B-47e8-9721-4577B7F124EA}\\AirSpace.Etw.man" L"/rf:C:\\Program Files\\Microsoft Office\\root\\VFS\\ProgramFilesCommonX86\\Microsoft Shared\\Office16\\mso.dll" L"/mf:C:\\Program Files\\Microsoft Office\\root\\VFS\\ProgramFilesCommonX86\\Microsoft Shared\\Office16\\mso.dll"
03b0:fixme:wevtutil:wmain stub: L"wevtutil.exe" L"im" L"C:\\ProgramData\\Microsoft\\ClickToRun\\{9AC08E99-230B-47e8-9721-4577B7F124EA}\\wordEtw.man" L"/rf:C:\\Program Files\\Microsoft Office\\root\\Office16\\wwlib.dll" L"/mf:C:\\Program Files\\Microsoft Office\\root\\Office16\\wwlib.dll"
03b8:fixme:wevtutil:wmain stub: L"wevtutil.exe" L"im" L"C:\\ProgramData\\Microsoft\\ClickToRun\\{9AC08E99-230B-47e8-9721-4577B7F124EA}\\AirSpace.Etw.man" L"/rf:C:\\Program Files\\Microsoft Office\\root\\VFS\\ProgramFilesCommonX86\\Microsoft Shared\\Office16\\mso.dll" L"/mf:C:\\Program Files\\Microsoft Office\\root\\VFS\\ProgramFilesCommonX86\\Microsoft Shared\\Office16\\mso.dll"
02a0:fixme:file:NtLockFile I/O completion on lock not implemented yet
014c:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (01D5F3D4 1 C) semi-stub
014c:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (01D5F284 1 C) semi-stub
03c8:fixme:combase:RoGetActivationFactory (L"Windows.Networking.Connectivity.NetworkInformation", {5074f851-950d-4165-9c15-365619481eea}, 00F7679C): semi-stub
03c8:err:combase:RoGetActivationFactory Failed to find library for L"Windows.Networking.Connectivity.NetworkInformation"
0148:fixme:win:RegisterPowerSettingNotification (0x3007c,{245d8541-3943-4422-b025-13a784f679b7},0): stub
0148:fixme:win:RegisterPowerSettingNotification (0x3007c,{5d3e9a59-e9d5-4b00-a6bd-ff34ff516548},0): stub
0148:fixme:win:RegisterPowerSettingNotification (0x3007c,{a7ad8041-b45a-4cae-87a3-eecbb468a9e1},0): stub
0148:fixme:win:RegisterPowerSettingNotification (0x3007c,{98a7f580-01f7-48aa-9c0f-44352c29e5c0},0): stub
0148:fixme:win:RegisterPowerSettingNotification (0x3007c,{02731015-4510-4526-99e6-e5a17ebd1aea},0): stub
0148:fixme:win:RegisterPowerSettingNotification (0x3007c,{3c0f4548-c03f-4c4d-b9f2-237ede686376},0): stub
02a0:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
014c:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (01D5EF28 1 C) semi-stub
014c:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (01D5EF88 1 C) semi-stub
014c:fixme:file:NtLockFile I/O completion on lock not implemented yet
014c:fixme:combase:RoGetActivationFactory (L"Windows.Security.Authentication.OnlineId.OnlineIdSystemAuthenticator", {85047792-f634-41e3-96a4-5164e902c740}, 01D5F2C4): semi-stub
014c:err:combase:RoGetActivationFactory Failed to find library for L"Windows.Security.Authentication.OnlineId.OnlineIdSystemAuthenticator"
014c:fixme:reg:NtQueryLicenseValue License key L"Microsoft-Windows-Container-License-Mode" not found
0280:fixme:win:RegisterPowerSettingNotification (0x300b6,{245d8541-3943-4422-b025-13a784f679b7},0): stub
0280:fixme:win:RegisterPowerSettingNotification (0x300b6,{5d3e9a59-e9d5-4b00-a6bd-ff34ff516548},0): stub
0280:fixme:win:RegisterPowerSettingNotification (0x300b6,{a7ad8041-b45a-4cae-87a3-eecbb468a9e1},0): stub
0280:fixme:win:RegisterPowerSettingNotification (0x300b6,{98a7f580-01f7-48aa-9c0f-44352c29e5c0},0): stub
0280:fixme:win:RegisterPowerSettingNotification (0x300b6,{02731015-4510-4526-99e6-e5a17ebd1aea},0): stub
0280:fixme:win:RegisterPowerSettingNotification (0x300b6,{3c0f4548-c03f-4c4d-b9f2-237ede686376},0): stub
02b8:fixme:win:RegisterPowerSettingNotification (0x100f8,{245d8541-3943-4422-b025-13a784f679b7},0): stub
02b8:fixme:win:RegisterPowerSettingNotification (0x100f8,{5d3e9a59-e9d5-4b00-a6bd-ff34ff516548},0): stub
02b8:fixme:win:RegisterPowerSettingNotification (0x100f8,{a7ad8041-b45a-4cae-87a3-eecbb468a9e1},0): stub
02b8:fixme:win:RegisterPowerSettingNotification (0x100f8,{98a7f580-01f7-48aa-9c0f-44352c29e5c0},0): stub
02b8:fixme:win:RegisterPowerSettingNotification (0x100f8,{02731015-4510-4526-99e6-e5a17ebd1aea},0): stub
02b8:fixme:win:RegisterPowerSettingNotification (0x100f8,{3c0f4548-c03f-4c4d-b9f2-237ede686376},0): stub
041c:fixme:heap:RtlSetHeapInformation 01280000 0 0105F15C 4 stub
02b8:fixme:win:UnregisterPowerSettingNotification (0xdeadbeef): stub
02a0:fixme:kernelbase:AppPolicyGetProcessTerminationMethod FFFFFFFA, 0031FE4C
0294:fixme:ntdll:EtwEventRegister ({9cc69d1c-7917-4acd-8066-6bf8b63e551b}, 07295240, 07334018, 07347BC8) stub.
0294:fixme:ntdll:EtwEventRegister ({e4f68870-5ae8-4e5b-9ce7-ca9ed75b0245}, 07295240, 07334050, 07347BD0) stub.
0294:fixme:ntdll:EtwEventRegister ({fb4a19ee-eb5a-47a4-bc52-e71aac6d0859}, 07295240, 07334088, 07347C48) stub.
0294:fixme:ntdll:EtwEventRegister ({94d97311-1bbb-4e11-b43d-994da5a64dc6}, 072221B0, 0727D050, 07280688) stub.
0294:fixme:ntdll:EtwEventRegister ({9cc69d1c-7917-4acd-8066-6bf8b63e551b}, 072221B0, 0727D088, 07280670) stub.
0294:fixme:ntdll:EtwEventRegister ({fb4a19ee-eb5a-47a4-bc52-e71aac6d0859}, 072221B0, 0727D018, 07280788) stub.
0294:fixme:ntdll:EtwEventActivityIdControl 0x1, 02E3E624: stub
0294:fixme:ntdll:EtwEventRegister ({9cc69d1c-7917-4acd-8066-6bf8b63e551b}, 073C2A60, 074540C0, 074592E0) stub.
0294:fixme:ntdll:EtwEventRegister ({fb4a19ee-eb5a-47a4-bc52-e71aac6d0859}, 073C2A60, 07454050, 074592C8) stub.
0294:fixme:ntdll:EtwEventRegister ({94d97311-1bbb-4e11-b43d-994da5a64dc6}, 073C2A60, 07454088, 074592B0) stub.
0294:fixme:ntdll:EtwEventRegister ({9cc69d1c-7917-4acd-8066-6bf8b63e551b}, 074BFF30, 07514050, 0752A2A0) stub.
0294:fixme:ntdll:EtwEventRegister ({fb4a19ee-eb5a-47a4-bc52-e71aac6d0859}, 074BFF30, 07514018, 0752A188) stub.
0294:fixme:ntdll:EtwEventRegister ({9cc69d1c-7917-4acd-8066-6bf8b63e551b}, 075A4D90, 075F00C0, 075F1F98) stub.
0294:fixme:ntdll:EtwEventRegister ({fb4a19ee-eb5a-47a4-bc52-e71aac6d0859}, 075A4D90, 075F0050, 075F1F88) stub.
0294:fixme:ntdll:EtwEventRegister ({94d97311-1bbb-4e11-b43d-994da5a64dc6}, 075A4D90, 075F0088, 075F1F68) stub.
0294:fixme:ntdll:EtwEventRegister ({94d97311-1bbb-4e11-b43d-994da5a64dc6}, 07601A50, 07675088, 07676EC8) stub.
0294:fixme:ntdll:EtwEventRegister ({fb4a19ee-eb5a-47a4-bc52-e71aac6d0859}, 07601A50, 07675050, 07676F08) stub.
0294:fixme:ntdll:EtwEventRegister ({9cc69d1c-7917-4acd-8066-6bf8b63e551b}, 07601A50, 07675018, 07676E88) stub.
0294:fixme:ntdll:EtwEventRegister ({e4f68870-5ae8-4e5b-9ce7-ca9ed75b0245}, 07684DB0, 0780B018, 07817AB8) stub.
0294:fixme:ntdll:EtwEventRegister ({9cc69d1c-7917-4acd-8066-6bf8b63e551b}, 07684DB0, 0780B088, 07817B88) stub.
0294:fixme:ntdll:EtwEventRegister ({fb4a19ee-eb5a-47a4-bc52-e71aac6d0859}, 07684DB0, 0780B050, 07817B48) stub.
0294:fixme:ntdll:EtwEventRegister ({e4f68870-5ae8-4e5b-9ce7-ca9ed75b0245}, 07971A10, 079A7050, 079A80D0) stub.
0294:fixme:ntdll:EtwEventRegister ({9cc69d1c-7917-4acd-8066-6bf8b63e551b}, 07971A10, 079A7018, 079A80C8) stub.
0294:fixme:ntdll:EtwEventRegister ({fb4a19ee-eb5a-47a4-bc52-e71aac6d0859}, 07971A10, 079A7088, 079A8148) stub.
0294:fixme:ntdll:EtwEventRegister ({9cc69d1c-7917-4acd-8066-6bf8b63e551b}, 078333D0, 0794C018, 07951308) stub.
0294:fixme:ntdll:EtwEventRegister ({e4f68870-5ae8-4e5b-9ce7-ca9ed75b0245}, 078333D0, 0794C050, 07951310) stub.
0294:fixme:ntdll:EtwEventRegister ({fb4a19ee-eb5a-47a4-bc52-e71aac6d0859}, 078333D0, 0794C088, 07951388) stub.
0294:fixme:userenv:GetProfileType 02E3E050
0294:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (02E3DEFC 1 C) semi-stub
0294:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (02E3DD2C 1 C) semi-stub
0294:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (02E3DCCC 1 C) semi-stub
0294:fixme:rpc:RpcServerRegisterIf3 Unsupported SecurityDescriptor argument.
0440:fixme:wtsapi:WTSEnumerateSessionsW Stub 00000000 0x00000000 0x00000001 07ABFC80 07ABFC94
0454:fixme:combase:RoGetActivationFactory (L"Windows.Networking.Connectivity.NetworkInformation", {5074f851-950d-4165-9c15-365619481eea}, 029A5FF4): semi-stub
0454:err:combase:RoGetActivationFactory Failed to find library for L"Windows.Networking.Connectivity.NetworkInformation"
0284:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (04FCF620 1 C) semi-stub
0284:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (04FCF680 1 C) semi-stub
0284:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (04FCF510 1 C) semi-stub
0284:fixme:file:NtLockFile I/O completion on lock not implemented yet
0284:fixme:combase:RoGetActivationFactory (L"Windows.Security.Authentication.OnlineId.OnlineIdSystemAuthenticator", {85047792-f634-41e3-96a4-5164e902c740}, 04FCF9DC): semi-stub
0284:err:combase:RoGetActivationFactory Failed to find library for L"Windows.Security.Authentication.OnlineId.OnlineIdSystemAuthenticator"
0284:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (04FCF834 1 C) semi-stub
0284:fixme:reg:NtQueryLicenseValue License key L"Microsoft-Windows-Container-License-Mode" not found
