Trying to build a 550 pc for some budget gaming need help!
im trying to build a budge gaming pc the budget would be around 550$ if anybody can help please post a link to some parts i should buy i have parts on my card on newegg but i can't share my card or at least i don't know how to
http://pcpartpicker.com/p/2bY8F
That's about all I could pack in at the price point... the mobo can overclock and run in crossfire, you get a decent video card (you're not going to be able to build with a nice video card for $550, but that card should play most things at high settings)
Nice CPU, good CPU cooler, good RAM, PSU is solid, HDD is basic but useable, solid case... pretty decent build for $550 IMHO
thanks
Nice build Panda but i noticed that it shows no price for the GPU.  Well I made a few changes to help the budget.
http://pcpartpicker.com/p/2deUt
I know it's tough with a tight budget so i took the CPU, PSU, GPU a step down saving about $60 once you factor in the MIR.  You didn't say you needed an operating system cause if you do you'll probably have to lose the GPU and go with the A-series and use the intergrated graphics which may be acceptable depending on what type of games you play.
