I have been advised that my 1st post was exceedingly long, and will probably alienate some potential readers. So I am taking one facet of that post and regurgitating it here, in hopes it might gain more attention from folks who might have first-hand experience.
I recently purchased a Gigabyte TRX40 Aorus Xtreme Motherboard to go with an equally-new AMD Threadripper 3960x. I read through the applicable parts of the MB’s User Manual, and explored the Internet (forums and videos) for information about the procedure, so that I was completely familiar with the procedure.
I tried assembling these devices a few days ago.
The first thing I noticed when I started the assembly was that there was no cover over the pins after I released the CPU Load Plate on the motherboard (User Manual Page 15, Step #7). Okay, some reviews had said that that cover was missing, but to my dismay, I also noticed a slight “blemish” on the pins in the top-right quadrant of the socket. I was now WORRIED!!! Had this board been tried/returned before?!
The second thing that happened was that after inserting the orange carrier frame into the rails, and closing down the Load Plate, I could NOT get Screw #1 to catch. After about 15 minutes of trying, I googled that issue, and found out that it has been an issue for several years now. Unfortunately, I can find no mention of it STILL happening with the sTRX4 Socket, so my earlier searches for TRX40 Installation guides did not turn it up.
I tried starting the other screws first (they worked okay), but doing so did not make Screw #1 able to reach. I tried different angles, different positioning of the Load Plate, and triple-checked that the orange carrier frame was indeed within the guide rails of the rail frame.
I eventually put the dummy protective plastic cover back into the slot, and found that Screw #1 (and all of them) went in fine. But retrying with the CPU-laden Orange Carrier Frame, however, left me in the same unsuccessful position. I was now getting a bit frantic.
Anyway, finally, after applying an uncomfortable amount of pressure, I managed to get the cover down and the screws secured until the wrench clicked.
But I was left with an assembly that would not boot, presenting me with a “D0” Debug Code.
I cannot find any mention of this problem happening to TRX40 installations. I see several mentions, going back at least two years, for other Threadripper generations (x399 in particular).
https://community.amd.com/thread/219286
… and many more.
I have since returned that MB to Amazon, and am awaiting its replacement.
I am wondering at this point just how prevalent this issue is with the TRX40 boards. Has anyone here had a similar experience? If so, how did you go about solving the problem? Hopefully, someone might have some pointers that will make my next attempt more successful.
Thank you so much for reading,
-pvs
