Woke up with an email from my secondary NAS that a disk had failed SMART. No biggie, I have a million spares but I want to know what went wrong
Going into the section of “SMART Test Results” gets me, well, no results!
Poked around in the UI and saw nothing, moved to CLI and did smartctl -a /dev/da10 and got this
Code:
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Vendor: HGST
Product: H7280A520SUN8.0T
Revision: PAG1
Compliance: SPC-4
User Capacity: 7,865,536,647,168 bytes [7.86 TB]
Logical block size: 512 bytes
Physical block size: 4096 bytes
Formatted with type 1 protection
8 bytes of protection information per logical block
LU is fully provisioned
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Logical Unit id: 0x5000cca260bd5228
Serial number: 001649PB3R5V VLKB3R5V
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Sat Oct 15 09:18:21 2022 CDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Temperature Warning: Enabled
=== START OF READ SMART DATA SECTION ===
SMART Health Status: OK
Current Drive Temperature: 36 C
Drive Trip Temperature: 85 C
Accumulated power on time, hours:minutes 45940:36
Manufactured in week 49 of year 2016
Specified cycle count over device lifetime: 50000
Accumulated start-stop cycles: 37
Specified load-unload count over device lifetime: 600000
Accumulated load-unload cycles: 1940
Elements in grown defect list: 0
Vendor (Seagate Cache) information
Blocks sent to initiator = 21759842658025472
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 23 0 23 18569405 1390483.328 0
write: 0 13 0 13 12180425 902791.191 0
verify: 0 0 0 0 84772 1.273 0
Non-medium error count: 0
SMART Self-test log
Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ]
Description number (hours)
# 1 Background short Failed in segment --> 3 45931 - [0x1 0x5d 0xfd]
# 2 Background short Completed - 45907 - [- - -]
# 3 Background short Completed - 45883 - [- - -]
# 4 Background short Completed - 45859 - [- - -]
# 5 Background short Completed - 45835 - [- - -]
# 6 Background short Completed - 45811 - [- - -]
# 7 Background short Completed - 45787 - [- - -]
# 8 Background short Completed - 45763 - [- - -]
# 9 Background short Completed - 45739 - [- - -]
#10 Background short Completed - 45715 - [- - -]
#11 Background short Completed - 45691 - [- - -]
#12 Background short Completed - 45667 - [- - -]
#13 Background short Completed - 45643 - [- - -]
#14 Background short Completed - 45619 - [- - -]
#15 Background short Completed - 45595 - [- - -]
#16 Background short Completed - 45571 - [- - -]
#17 Background short Completed - 45547 - [- - -]
#18 Background short Completed - 45523 - [- - -]
#19 Background short Completed - 45499 - [- - -]
#20 Background short Completed - 45475 - [- - -]
Long (extended) Self-test duration: 63865 seconds [1064.4 minutes]
So I can see it failed on “Segment 3”, but what the heck is segment 3?
Never worked this hard in a NAS OS to see results before!
Is my best put pulling it out and throwing it into a Windows box and using hard disk sentinel etc?
I didn’t want to pull it and find the error was something stupid
