TrueNAS Scale: Ultimate Home Setup incl. Tailscale
That’s exactly what docker desktop is.
You’re not actually trying to listen and understand my point, you’re just trying to prove yours, so good luck with that.
May I chip in? I am a total noob when it comes to docker, still find it confusing. I tried to follow Wndells guide but some things are not explained well to people like me. I got stuck and gave up… Until, I found the guide made by @PapaGigas.
It’s super comprehensive and easy to follow, I’d say it guide me at every step, everything just works. Well, few thing could be better explained but I’m quite happy.
As for portainer, I find it confusing more than Dockge, maybe it’s because it’s more difficult to use for me, maybe it’s a matter of getting used to. Well, I’m a nood so what do I know :stuck_out_tongue_winking_eye:.
I’m just happy I found your tutorial @PapaGigas, because I don’t have tospend so much time searching through forums or the whole of the Internet. Good job, I appreciate your time making it.
I just see no point in arguing over which way of managing dockers is better, whatever suits you or you do you I will do it my way. Peace.
I’m happy to see that my guide has been helpful, even if it’s just to one person. :sweat_smile:
When I get back home next week, I’ll focus on finishing the guide and clarifying any points that need revision. Until then, good luck with everything! :wink:
Best regards,
PapaGigas
Beware that TrueNAS Scale will change from KVM to Incus in the next release…
Or in other words: it will break your VM setup! :roll_eyes:
Source:
Best regards,
PapaGigas
What the hell even is an Incus-powered containers and virtual machines
Ok…
This is how it looks (at least for now) in TrueNAS Scale:
Instances Screens
Best regards,
PapaGigas
