got the gpu to show up in the app finally but i got this error when trying to save the app.
EFAULT] Failed to render compose templates: Traceback (most recent call last): File “/usr/bin/apps_render_app”, line 33, in sys.exit(load_entry_point(‘apps-validation==0.1’, ‘console_scripts’, ‘apps_render_app’)()) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py”, line 48, in main render_templates_from_path(args.path, args.values) File “/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py”, line 19, in render_templates_from_path rendered_data = render_templates( ^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/catalog_templating/render.py”, line 31, in render_templates rendered_templates[i.name] = env.get_template(i.name).render( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/jinja2/environment.py”, line 1301, in render self.environment.handle_exception() File “/usr/lib/python3/dist-packages/jinja2/environment.py”, line 936, in handle_exception raise rewrite_traceback_stack(source=source) File “/mnt/.ix-apps/app_configs/plex/versions/1.1.22/templates/docker-compose.yaml”, line 3, in top-level template code {% set c1 = tpl.add_container(values.consts.plex_container_name, values.plex.image_selector) %} ^^^^^^^^^^^^^^^^^^^^^^^^^ File “/mnt/.ix-apps/app_configs/plex/versions/1.1.22/templates/library/base_v2_1_16/render.py”, line 59, in add_container container = Container(self, name, image) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/mnt/.ix-apps/app_configs/plex/versions/1.1.22/templates/library/base_v2_1_16/container.py”, line 94, in init self.deploy: Deploy = Deploy(self._render_instance) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/mnt/.ix-apps/app_configs/plex/versions/1.1.22/templates/library/base_v2_1_16/deploy.py”, line 15, in init self.resources: Resources = Resources(self._render_instance) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/mnt/.ix-apps/app_configs/plex/versions/1.1.22/templates/library/base_v2_1_16/resources.py”, line 24, in init self._auto_add_gpus_from_values() File “/mnt/.ix-apps/app_configs/plex/versions/1.1.22/templates/library/base_v2_1_16/resources.py”, line 55, in _auto_add_gpus_from_values raise RenderError(f"Expected [uuid] to be set for GPU in slot [{pci}] in [nvidia_gpu_selection]“) base_v2_1_16.error.RenderError: Expected [uuid] to be set for GPU in slot [0000:02:00.0] in [nvidia_gpu_selection]
More info…
Error: Traceback (most recent call last):
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 515, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 562, in __run_body
rv = await self.middleware.run_in_thread(self.method, *args)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 599, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 596, in run_in_executor
return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs))
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
result = self.fn(*self.args, **self.kwargs)
File “/usr/lib/python3/dist-packages/middlewared/service/crud_service.py”, line 294, in nf
rv = func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py”, line 96, in wrapped
result = func(*args)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 229, in do_update
app = self.update_internal(job, app, data, trigger_compose=app[‘state’] != ‘STOPPED’)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 259, in update_internal
update_app_config(app_name, app[‘version’], new_values, custom_app=app[‘custom_app’])
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py”, line 60, in update_app_config
render_compose_templates(
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py”, line 51, in render_compose_templates
raise CallError(f’Failed to render compose templates: {cp.stderr}')
middlewared.service_exception.CallError: [EFAULT] Failed to render compose templates: Traceback (most recent call last):
raise RenderError(f"Expected [uuid] to be set for GPU in slot [{pci}] in [nvidia_gpu_selection]”)
