Odair
1
Hi
Can someone help me?
If I did understand, the Asus ROG STRIX B650-A GAMING WIFI ATX AM5 Motherboard supports ECC memory
From Asus website "
4 x DIMM, Max. 128GB, DDR5 6400+(OC)/ 6200(OC)/ 6000(OC)/ 5800(OC)/ 5600(OC)/ 5400(OC)/ 5200/ 5000/ 4800 ECC and Non-ECC, Un-buffered Memory"
It says ECC and Non-ECC, right?
but PcPartPicker says otherwise
On Asus website it says this memory KINGSTON KSM48E40BD8KM-32HM 32GB is compatible with the mobo.
Answers so far are it does support ecc, but it might not support all ecc features
Thanks in advance!
It should run fine with ecc udimms (not rdimms).
Check the bios version as well as some later agesa updates unlock memory compatibility, so you may need to update.
Good luck
diizzy
3
Should be fine however I would recommend stepping up to ROG STRIX B650E-F WIFI as that’s a 8 layer PCB instead of 6 according to
AM5 Motherboards Sheet (X870/X670/B650/A620) - Google Sheets especially if you plan on going for 128Gb.
The Kingston memory and | mtc20c2085s1ec48br | Crucial EU (both speeds) should be fine. That being said, 5600 is a waste if you’re going for 4 DIMMs.
system
Closed
4
