I use it with MQTT and HA.
Oh, sorry I just remembered, if not a problem there is one last thing you could add - Nebula Synq for synchronizising settings between two or more Pi-Holes.
No problem… I’ll add it to DNS-DHCP stack!
EDIT: I’ve added Nebula-Sync as requested, can you test it please?
EDIT2: I’ve disabled the full sync… just in case!
Best regards,
PapaGigas
Nebula Service doesn’t start:
2025-04-19T16:22:04Z FTL Failed to initialize service error=“parse url: parse "\"https://172.17.6.2:8082": first path segment in URL cannot contain colon”
Hummm… I’ve removed the port, can you check again?
EDIT: I’ve also changed Pi-hole’s ports to 80 and 443!
EDIT2: I’ve also updated the ports for Kali, Wireshark, and NetAlertX to use 80/443… now you can access them without needing to specify ports!
Best regards,
PapaGigas
Unfortunately, I still get the same error.
Pi-Hole, Kali, Wireshark and NetalertX all work fine after changes were applied.
Thanks.
I’ve changed the IP address of the primary Pi-hole… can you check again?
Best regards,
PapaGigas
Sorry, no change, still spamming the same error in the logs.
Are you sure it’s always the same “URL cannot contain colon” error?
Delete the Nebula-Sync container/data in Portainer, then redeploy the stack!
Best regards,
PapaGigas
Yes:
2025-04-20T12:38:04Z FTL Failed to initialize service error="parse url: parse \"\\\"https://172.17.6.2\": first path segment in URL cannot contain colon"
2025-04-20T12:39:05Z FTL Failed to initialize service error="parse url: parse \"\\\"https://172.17.6.2\": first path segment in URL cannot contain colon"
Use CTRL+F5 to refresh the guide, you’re still using the internal IP address…
Best regards,
PapaGigas
Hmm, strange I thought I refreshed the window before… Anyway, the service works now.
Still getting some errors but I think this is due to my second Pi-hole that runs on RPi, need to fix that, it has nothing to do with this config.
Quick question, after I changed the ports I just noticed I can only access Netalertx through its local ip.
Restart Traefik’'s container in Portainer!
PS: Your secondary Pi-hole should be running version 6… that’s probably why your getting those errors… I’ll put a warning regarding that fact on the guide!
18 - If you don't have a secondary Pi-hole, delete the "nebula-sync" container. # Just like you did for the "nginx" container
# WARNING: If you have a secondary Pi-hole, make sure you upgrade to Pi-hole version 6 before deploying this stack or Nebula-Sync will fail!
Best regards,
PapaGigas
Both of my Pi-Holes run version 6 now. Anyway…
Restart of Traefik didn’t help.
I can access Netalertx through:
http://10.0.1.212
but:
https://netalertx.int.local/
- returns 404
When I looked at the docker config, NetalertX only has port 80 assigned, there is no entry for 443. Is this correct?
EDIT: It took a while for tailscale but I can now access it over ther. Not locally though, except for local ip address without the port.
hummm… that’s because I’ve changed the domains:
PS: You can update all of your stacks and DNS entries… or… you can just change traefik’s labels for now in NetAlertX service (to use the int subdomain)!
Best regards,
PapaGigas
OK, thank you again for all your hard work and all the help.
You’re welcome… and also thank you for all your feedback!
EDIT: Btw, I’ve added this step to DEV stack:
18 - If you only need "node-red" for managing Home Assistant, delete the rest of the containers in this stack. # Just like you did for the "nginx" container
EDIT2: I’ve also added this steps to HOME stack:
24 - If you didn't install the "LOCAL AI" stack (to use Ollama LLM's in your Home Assistant), remove the ollama network from "networks" at the end of the stack:
ollama:
external: true
25 - If you didn't install the "LOCAL AI" stack (to use Ollama LLM's in your Home Assistant), remove the ollama network from "homeassistant" service:
ollama:
ipv4_address: 172.17.18.4
26 - If you didn't install the "DEV" stack (to use Node-RED for managing Home Assistant), remove the dev network from "networks" at the end of the stack:
dev:
external: true
27 - If you didn't install the "DEV" stack (to use Node-RED for managing Home Assistant), remove the dev network from "mosquitto" and "homeassistant" services:
dev:
ipv4_address: 172.17.25.x
Best regards,
PapaGigas
I’ve changed the WordPress stack from WEBSITE to CMS… and created a WEBSITE stack for Nginx!
Best regards,
PapaGigas
One suggestion I have, it would be wise to add the information about changing some setting in slave machines running Pi-Hole, I had some authentication issues which I resolved by:
From the Pi-hole web UI, go to Settings → All Settings. Toggle the “Modified settings / All settings” slider in the upper right to show “All settings”. Choose the “Webserver and API” section. Check the “Enabled” box under
webserver.api.app_sudo
and then click “Save & Apply”. Repeat for each replica.
I re-installed the whole Pi-Hole system on my sdcard on my RPi because I could’t authenticate Nebulasync on it. Having said that, this might only apply to if someone uses app paswords. On my clean Pi-Hole I didn’t try regular passwords, nonethless I think this info might come handy, it’s from the project’s github.
I am yet to test the Node Red, need to find some free time and I will come back with the feedback, thanks again.
I’ll put a warning regarding that, thanks!
Btw, I’ve added DOCKER IMAGE UPDATE NOTIFIER to the NOTIFICATIONS stack!
EDIT: I’ve added this steps to the DNS-DHCP installation instructions:
20 - If you don't have a secondary Pi-hole, ignore steps 21-24 and delete the "nebula-sync" container. # Just like you did for the "nginx" container
# WARNING: Make sure you upgrade your secondary Pi-hole to Pi-hole version 6 before deploying this stack or Nebula-Sync will fail!
21 - Open your secondary Pi-hole Web interface and navigate to "Settings > All Settings".
22 - Toggle the "Modified settings / All settings" slider in the upper right to show "All settings".
23 - Choose the "Webserver and API" section and check the "Enabled" box under "webserver.api.app_sudo".
24 - Click "Save & Apply" to allow Nebula-Sync to make changes to your secondary Pi-hole.
25 - Go back to Dockge's Web interface and click "Deploy" to install.
Best regards,
PapaGigas
I decided to test the whole DEV stack in order to provide you with feedback.
The .env is missing underscore here:
CODE_SERVER_SUDO PASSWORD=admin
In general there is something wrong in the Docker compose config of this stack, when I copy everything I get this:
Error response from daemon: invalid reference format
By elimination I found it must be Gitlab, only after its removal remaining containers are getting pulled.
Node Red doesn’t want to start, because it needs additional permissions:
node-red | /usr/src/node-red/node_modules/fs-extra/lib/util/stat.js:30
node-red | throw err
node-red | ^
node-red |
node-red | Error: EACCES: permission denied, lstat '/data/settings.js'
node-red | at Object.lstatSync (node:fs:1642:25)
node-red | at Object.lstatSync (/usr/src/node-red/node_modules/graceful-fs/polyfills.js:318:34)
node-red | at statFunc (/usr/src/node-red/node_modules/fs-extra/lib/util/stat.js:24:20)
node-red | at getStatsSync (/usr/src/node-red/node_modules/fs-extra/lib/util/stat.js:27:16)
node-red | at Object.checkPathsSync (/usr/src/node-red/node_modules/fs-extra/lib/util/stat.js:64:33)
node-red | at Object.copySync (/usr/src/node-red/node_modules/fs-extra/lib/copy/copy-sync.js:27:38)
node-red | at Object.<anonymous> (/usr/src/node-red/node_modules/node-red/red.js:148:20)
node-red | at Module._compile (node:internal/modules/cjs/loader:1529:14)
node-red | at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
node-red | at Module.load (node:internal/modules/cjs/loader:1275:32) {
node-red | errno: -13,
node-red | code: 'EACCES',
node-red | syscall: 'lstat',
node-red | path: '/data/settings.js'
node-red | }
node-red |
node-red | Node.js v20.19.0
node-red exited with code 0
Node-postgress complains about dependancies:
dependency failed to start: container node-postgres is unhealthy
Only Coder runs without any issues.
