Hey. Finally decided to rebuild my PC that I made back in 2011. I've gradually replaced GPUs, Powersupplies and Harddrives over the past few years though.
I've spent the past few days troubleshooting the issues, I simply cant work it out. Essentially, the PC will not boot - or if it does, the CPU fan spins for a second then stops.
I've tried taking out my RAM, my GPU, my Bluray drive and plugging different components with different power cables. I'm currently trying to re-rebuild everything just to see if I missed anything. I'm salvaging most of my components, aside from the Motherboard, CPU, CPU fan and case which are all new. I've noticed that my Fractal R4 case does not have a hdd led cable, though this wouldn't be an issue. The Case has been wired correctly after checking and checking.
The PC consists of:
Intel i7 4970k
ASrock z97x Killer Fatality
Corsair h80i
Corsair Vengeance 16gb 780
Corsair CX750
Asus GTX 780
Kingston HyperX 240gb
Seagate Barracuda 3TB
Fractal Design R4
This is blowing my mind, i've spent hours searching the answers online but nothing seems to resolve my problem. Honestly, does it just come down to a defective part? I'm even close to sending it into a shop, i'm close to not even caring.
Thanks,
Andrew
