Troubleshoot zfs error: PANIC at zfs_znode.c:611:zfs_znode_alloc()
Hello,
Any help troubleshooting would be greatly appreciated. I have a Proxmox system that is giving a kernel panic which seems to happen randomly (doesn’t do it every time) when using a zfs send command.
  • system is running proxmox 6.0
  • pyznap to run the zfs send command
  • send command is sending between pools on the same machine
  • both pools show zeros errors on zpool status.
  • running amd 3900x on MSI meg ace x570 board
Kernel
⁠Linux version 5.0.15-1-pve (build@pve) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP PVE 5.0.15-1 (Wed, 03 Jul 2019 10:51:57 +0200)
ZFS
⁠⁠zfs-0.8.2-pve2
⁠zfs-kmod-0.8.1-pve
Googling provide much help with the messages below:
dmesg gives the following:
 VERIFY3(insert_inode_locked(ip) == 0) failed (-16 == 0)
[113512.912807] PANIC at zfs_znode.c:611:zfs_znode_alloc()
[113512.912808] Showing stack for process 1975
[113512.912811] CPU: 4 PID: 1975 Comm: z_unlinked_drai Tainted: P           O      5.0.15-1-pve #1
[113512.912813] Hardware name: Micro-Star International Co., Ltd. MS-7C35/MEG X570 ACE (MS-7C35), BIOS 1.50 09/16/2019
[113512.912815] Call Trace:
[113512.912822]  dump_stack+0x63/0x8a
[113512.912830]  spl_dumpstack+0x29/0x2b [spl]
[113512.912833]  spl_panic+0xd3/0xfb [spl]
[113512.912837]  ? spl_kmem_cache_free+0xc0/0x1d0 [spl]
[113512.912873]  ? zfs_inode_destroy+0xf8/0x110 [zfs]
[113512.912901]  ? zpl_inode_destroy+0xe/0x10 [zfs]
[113512.912903]  ? destroy_inode+0x3e/0x60
[113512.912905]  ? evict+0x139/0x1a0
[113512.912906]  ? iput+0x148/0x210
[113512.912908]  ? insert_inode_locked+0x1d8/0x1e0
[113512.912933]  zfs_znode_alloc+0x625/0x680 [zfs]
[113512.912958]  zfs_zget+0x1ad/0x240 [zfs]
[113512.912984]  zfs_unlinked_drain_task+0x74/0x100 [zfs]
[113512.912987]  ? __switch_to_asm+0x34/0x70
[113512.912989]  ? __switch_to_asm+0x40/0x70
[113512.912990]  ? __switch_to_asm+0x34/0x70
[113512.912991]  ? __switch_to_asm+0x40/0x70
[113512.912993]  ? __switch_to_asm+0x34/0x70
[113512.912996]  ? finish_task_switch+0xcd/0x270
[113512.912998]  ? __schedule+0x2dc/0x870
[113512.913000]  ? remove_wait_queue+0x4d/0x60
[113512.913004]  taskq_thread+0x2ec/0x4d0 [spl]
[113512.913007]  ? wake_up_q+0x80/0x80
[113512.913009]  kthread+0x120/0x140
[113512.913013]  ? task_done+0xb0/0xb0 [spl]
[113512.913015]  ? __kthread_parkme+0x70/0x70
[113512.913016]  ret_from_fork+0x22/0x40
[113704.620941] INFO: task z_unlinked_drai:1975 blocked for more than 120 seconds.
[113704.620947]       Tainted: P           O      5.0.15-1-pve #1
[113704.620949] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[113704.620951] z_unlinked_drai D    0  1975      2 0x80000000
[113704.620954] Call Trace:
[113704.620961]  __schedule+0x2d4/0x870
[113704.620965]  schedule+0x2c/0x70
[113704.620971]  spl_panic+0xf9/0xfb [spl]
[113704.620975]  ? spl_kmem_cache_free+0xc0/0x1d0 [spl]
[113704.621009]  ? zfs_inode_destroy+0xf8/0x110 [zfs]
[113704.621036]  ? zpl_inode_destroy+0xe/0x10 [zfs]
[113704.621038]  ? destroy_inode+0x3e/0x60
[113704.621040]  ? evict+0x139/0x1a0
[113704.621041]  ? iput+0x148/0x210
[113704.621043]  ? insert_inode_locked+0x1d8/0x1e0
[113704.621068]  zfs_znode_alloc+0x625/0x680 [zfs]
[113704.621093]  zfs_zget+0x1ad/0x240 [zfs]
[113704.621119]  zfs_unlinked_drain_task+0x74/0x100 [zfs]
[113704.621122]  ? __switch_to_asm+0x34/0x70
[113704.621123]  ? __switch_to_asm+0x40/0x70
[113704.621125]  ? __switch_to_asm+0x34/0x70
[113704.621126]  ? __switch_to_asm+0x40/0x70
[113704.621127]  ? __switch_to_asm+0x34/0x70
[113704.621130]  ? finish_task_switch+0xcd/0x270
[113704.621132]  ? __schedule+0x2dc/0x870
[113704.621135]  ? remove_wait_queue+0x4d/0x60
[113704.621139]  taskq_thread+0x2ec/0x4d0 [spl]
[113704.621141]  ? wake_up_q+0x80/0x80
[113704.621143]  kthread+0x120/0x140
[113704.621147]  ? task_done+0xb0/0xb0 [spl]
[113704.621149]  ? __kthread_parkme+0x70/0x70
[113704.621150]  ret_from_fork+0x22/0x40
[113825.453664] INFO: task z_unlinked_drai:1975 blocked for more than 120 seconds.
[113825.453670]       Tainted: P           O      5.0.15-1-pve #1
[113825.453672] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[113825.453674] z_unlinked_drai D    0  1975      2 0x80000000
[113825.453678] Call Trace:
[113825.453685]  __schedule+0x2d4/0x870
[113825.453689]  schedule+0x2c/0x70
[113825.453695]  spl_panic+0xf9/0xfb [spl]
[113825.453700]  ? spl_kmem_cache_free+0xc0/0x1d0 [spl]
[113825.453741]  ? zfs_inode_destroy+0xf8/0x110 [zfs]
[113825.453773]  ? zpl_inode_destroy+0xe/0x10 [zfs]
[113825.453776]  ? destroy_inode+0x3e/0x60
[113825.453778]  ? evict+0x139/0x1a0
[113825.453779]  ? iput+0x148/0x210
[113825.453781]  ? insert_inode_locked+0x1d8/0x1e0
[113825.453812]  zfs_znode_alloc+0x625/0x680 [zfs]
[113825.453841]  zfs_zget+0x1ad/0x240 [zfs]
[113825.453872]  zfs_unlinked_drain_task+0x74/0x100 [zfs]
[113825.453875]  ? __switch_to_asm+0x34/0x70
[113825.453877]  ? __switch_to_asm+0x40/0x70
[113825.453878]  ? __switch_to_asm+0x34/0x70
[113825.453880]  ? __switch_to_asm+0x40/0x70
[113825.453882]  ? __switch_to_asm+0x34/0x70
[113825.453885]  ? finish_task_switch+0xcd/0x270
[113825.453887]  ? __schedule+0x2dc/0x870
[113825.453889]  ? remove_wait_queue+0x4d/0x60
[113825.453894]  taskq_thread+0x2ec/0x4d0 [spl]
[113825.453897]  ? wake_up_q+0x80/0x80
[113825.453900]  kthread+0x120/0x140
[113825.453904]  ? task_done+0xb0/0xb0 [spl]
[113825.453906]  ? __kthread_parkme+0x70/0x70
[113825.453908]  ret_from_fork+0x22/0x40
[113946.286504] INFO: task z_unlinked_drai:1975 blocked for more than 120 seconds.
[113946.286509]       Tainted: P           O      5.0.15-1-pve #1
[113946.286510] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[113946.286513] z_unlinked_drai D    0  1975      2 0x80000000
[113946.286515] Call Trace:
[113946.286521]  __schedule+0x2d4/0x870
[113946.286525]  schedule+0x2c/0x70
[113946.286531]  spl_panic+0xf9/0xfb [spl]
[113946.286535]  ? spl_kmem_cache_free+0xc0/0x1d0 [spl]
[113946.286569]  ? zfs_inode_destroy+0xf8/0x110 [zfs]
[113946.286596]  ? zpl_inode_destroy+0xe/0x10 [zfs]
[113946.286599]  ? destroy_inode+0x3e/0x60
[113946.286600]  ? evict+0x139/0x1a0
[113946.286602]  ? iput+0x148/0x210
[113946.286603]  ? insert_inode_locked+0x1d8/0x1e0
[113946.286629]  zfs_znode_alloc+0x625/0x680 [zfs]
[113946.286654]  zfs_zget+0x1ad/0x240 [zfs]
[113946.286681]  zfs_unlinked_drain_task+0x74/0x100 [zfs]
[113946.286683]  ? __switch_to_asm+0x34/0x70
[113946.286685]  ? __switch_to_asm+0x40/0x70
[113946.286686]  ? __switch_to_asm+0x34/0x70
[113946.286687]  ? __switch_to_asm+0x40/0x70
[113946.286689]  ? __switch_to_asm+0x34/0x70
[113946.286691]  ? finish_task_switch+0xcd/0x270
[113946.286693]  ? __schedule+0x2dc/0x870
[113946.286695]  ? remove_wait_queue+0x4d/0x60
[113946.286700]  taskq_thread+0x2ec/0x4d0 [spl]
[113946.286702]  ? wake_up_q+0x80/0x80
[113946.286704]  kthread+0x120/0x140
[113946.286708]  ? task_done+0xb0/0xb0 [spl]
[113946.286710]  ? __kthread_parkme+0x70/0x70
[113946.286711]  ret_from_fork+0x22/0x40
[114067.119208] INFO: task z_unlinked_drai:1975 blocked for more than 120 seconds.
[114067.119213]       Tainted: P           O      5.0.15-1-pve #1
[114067.119214] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[114067.119216] z_unlinked_drai D    0  1975      2 0x80000000
[114067.119219] Call Trace:
[114067.119226]  __schedule+0x2d4/0x870
[114067.119229]  schedule+0x2c/0x70
[114067.119235]  spl_panic+0xf9/0xfb [spl]
[114067.119240]  ? spl_kmem_cache_free+0xc0/0x1d0 [spl]
[114067.119274]  ? zfs_inode_destroy+0xf8/0x110 [zfs]
[114067.119301]  ? zpl_inode_destroy+0xe/0x10 [zfs]
[114067.119304]  ? destroy_inode+0x3e/0x60
[114067.119305]  ? evict+0x139/0x1a0
[114067.119307]  ? iput+0x148/0x210
[114067.119308]  ? insert_inode_locked+0x1d8/0x1e0
[114067.119334]  zfs_znode_alloc+0x625/0x680 [zfs]
[114067.119359]  zfs_zget+0x1ad/0x240 [zfs]
[114067.119385]  zfs_unlinked_drain_task+0x74/0x100 [zfs]
[114067.119387]  ? __switch_to_asm+0x34/0x70
[114067.119389]  ? __switch_to_asm+0x40/0x70
[114067.119390]  ? __switch_to_asm+0x34/0x70
[114067.119391]  ? __switch_to_asm+0x40/0x70
[114067.119393]  ? __switch_to_asm+0x34/0x70
[114067.119395]  ? finish_task_switch+0xcd/0x270
[114067.119397]  ? __schedule+0x2dc/0x870
[114067.119399]  ? remove_wait_queue+0x4d/0x60
[114067.119404]  taskq_thread+0x2ec/0x4d0 [spl]
[114067.119406]  ? wake_up_q+0x80/0x80
[114067.119408]  kthread+0x120/0x140
[114067.119412]  ? task_done+0xb0/0xb0 [spl]
[114067.119413]  ? __kthread_parkme+0x70/0x70
[114067.119415]  ret_from_fork+0x22/0x40
[114110.523937]  zd96: p1
[114187.952077] INFO: task z_unlinked_drai:1975 blocked for more than 120 seconds.
[114187.952083]       Tainted: P           O      5.0.15-1-pve #1
[114187.952084] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[114187.952086] z_unlinked_drai D    0  1975      2 0x80000000
[114187.952089] Call Trace:
[114187.952096]  __schedule+0x2d4/0x870
[114187.952099]  schedule+0x2c/0x70
[114187.952106]  spl_panic+0xf9/0xfb [spl]
[114187.952110]  ? spl_kmem_cache_free+0xc0/0x1d0 [spl]
[114187.952146]  ? zfs_inode_destroy+0xf8/0x110 [zfs]
[114187.952174]  ? zpl_inode_destroy+0xe/0x10 [zfs]
[114187.952177]  ? destroy_inode+0x3e/0x60
[114187.952178]  ? evict+0x139/0x1a0
[114187.952179]  ? iput+0x148/0x210
[114187.952181]  ? insert_inode_locked+0x1d8/0x1e0
[114187.952207]  zfs_znode_alloc+0x625/0x680 [zfs]
[114187.952233]  zfs_zget+0x1ad/0x240 [zfs]
[114187.952260]  zfs_unlinked_drain_task+0x74/0x100 [zfs]
[114187.952262]  ? __switch_to_asm+0x34/0x70
[114187.952264]  ? __switch_to_asm+0x40/0x70
[114187.952265]  ? __switch_to_asm+0x34/0x70
[114187.952267]  ? __switch_to_asm+0x40/0x70
syslog gives the following:
Dec 20 01:00:03 pve kernel: [113512.912807] PANIC at zfs_znode.c:611:zfs_znode_alloc()
Dec 20 01:00:03 pve kernel: [113512.912811] CPU: 4 PID: 1975 Comm: z_unlinked_drai Tainted: P           O      5.0.15-1-pve #1
Dec 20 01:00:03 pve kernel: [113512.912815] Call Trace:
Dec 20 01:00:03 pve kernel: [113512.912830]  spl_dumpstack+0x29/0x2b [spl]
Dec 20 01:00:03 pve kernel: [113512.912837]  ? spl_kmem_cache_free+0xc0/0x1d0 [spl]
Dec 20 01:00:03 pve kernel: [113512.912901]  ? zpl_inode_destroy+0xe/0x10 [zfs]
Dec 20 01:00:03 pve kernel: [113512.912905]  ? evict+0x139/0x1a0
Dec 20 01:00:03 pve kernel: [113512.912908]  ? insert_inode_locked+0x1d8/0x1e0
Dec 20 01:00:03 pve kernel: [113512.912958]  zfs_zget+0x1ad/0x240 [zfs]
Dec 20 01:00:03 pve kernel: [113512.912987]  ? __switch_to_asm+0x34/0x70
Dec 20 01:00:03 pve kernel: [113512.912990]  ? __switch_to_asm+0x34/0x70
Dec 20 01:00:03 pve kernel: [113512.912991]  ? __switch_to_asm+0x40/0x70
Dec 20 01:00:03 pve kernel: [113512.912993]  ? __switch_to_asm+0x34/0x70
Dec 20 01:00:03 pve kernel: [113512.912996]  ? finish_task_switch+0xcd/0x270
Dec 20 01:00:03 pve kernel: [113512.912998]  ? __schedule+0x2dc/0x870
Dec 20 01:00:03 pve kernel: [113512.913000]  ? remove_wait_queue+0x4d/0x60
Dec 20 01:00:03 pve kernel: [113512.913004]  taskq_thread+0x2ec/0x4d0 [spl]
Dec 20 01:00:03 pve kernel: [113512.913007]  ? wake_up_q+0x80/0x80
Dec 20 01:00:03 pve kernel: [113512.913009]  kthread+0x120/0x140
Dec 20 01:00:03 pve kernel: [113512.913013]  ? task_done+0xb0/0xb0 [spl]
Dec 20 01:00:03 pve kernel: [113512.913015]  ? __kthread_parkme+0x70/0x70
Dec 20 01:00:03 pve kernel: [113512.913016]  ret_from_fork+0x22/0x40
I would raise a bug report with ZOL Proxmox (Edit: as it’s not offically supported, try proxmox first)
Does it always do it eventually when sending, or only sometimes?
It only does it sometimes.
Thanks, I’ll submit a bug report. Not quite sure how to make it reproducible though.
yeah.
If it was always / common / reproducable, would poke at a few things, see if maybe could tweak, but otherwise, see if Proxmox will take a bug report- they might have an answer, or might refer you up to ZOL.
They might not have any answers, but having the info would help them in case others have the issue, so the more info they have, the better…
I am getting the same every 3-4 weeks. Seems to be triggered by higher loads. In this case this server was doing z very long zfs send (~25TB) while at the same time ingesting small incremental zfs receives (a few gigabytes) when one of the zfs receive got stuck in this PANIC situation.
I have tried to tune a lot of zfs module parameters, but this keeps coming back and nothing seem to help. After this PANIC I need to carefully reboot the server. It seems to help to export the pool manually before reboot, which fails due to the stuck zfs receive, but seems help to clean up something. Unless I do that manual export the zpool takes a lot of time to import on next boot.
[Mon Dec 28 23:38:08 2020] VERIFY3(insert_inode_locked(ip) == 0) failed (-16 == 0)
[Mon Dec 28 23:38:08 2020] PANIC at zfs_znode.c:611:zfs_znode_alloc()
[Mon Dec 28 23:38:08 2020] Showing stack for process 1477
[Mon Dec 28 23:38:08 2020] CPU: 15 PID: 1477 Comm: z_unlinked_drai Tainted: P W O 5.4.0-56-generic #62-Ubuntu
[Mon Dec 28 23:38:08 2020] Hardware name: HP ProLiant DL380p Gen8, BIOS P70 12/20/2015
[Mon Dec 28 23:38:08 2020] Call Trace:
[Mon Dec 28 23:38:08 2020] dump_stack+0x6d/0x9a
[Mon Dec 28 23:38:08 2020] spl_dumpstack+0x29/0x2b [spl]
[Mon Dec 28 23:38:08 2020] spl_panic+0xd4/0x102 [spl]
[Mon Dec 28 23:38:08 2020] ? zrl_add_impl+0xa0/0xb0 [zfs]
[Mon Dec 28 23:38:08 2020] ? atomic_dec_return+0x9/0x10 [zfs]
[Mon Dec 28 23:38:08 2020] ? atomic_cmpxchg+0x16/0x30 [zfs]
[Mon Dec 28 23:38:08 2020] ? atomic_sub_return.constprop.0+0xd/0x20 [zfs]
[Mon Dec 28 23:38:08 2020] ? iput+0x7d/0x210
[Mon Dec 28 23:38:08 2020] ? insert_inode_locked+0x1d5/0x1e0
[Mon Dec 28 23:38:08 2020] zfs_znode_alloc+0x54a/0x570 [zfs]
[Mon Dec 28 23:38:08 2020] zfs_zget+0x24a/0x290 [zfs]
[Mon Dec 28 23:38:08 2020] zfs_unlinked_drain_task+0x74/0x100 [zfs]
[Mon Dec 28 23:38:08 2020] ? __switch_to_asm+0x34/0x70
[Mon Dec 28 23:38:08 2020] ? __switch_to_asm+0x40/0x70
[Mon Dec 28 23:38:08 2020] ? __switch_to+0x7f/0x470
[Mon Dec 28 23:38:08 2020] ? __schedule+0x2eb/0x740
[Mon Dec 28 23:38:08 2020] ? __wake_up_common_lock+0x8a/0xc0
[Mon Dec 28 23:38:08 2020] ? __list_add+0x17/0x40 [spl]
[Mon Dec 28 23:38:08 2020] ? list_add+0xc/0x10 [spl]
[Mon Dec 28 23:38:08 2020] taskq_thread+0x245/0x430 [spl]
[Mon Dec 28 23:38:08 2020] ? wake_up_q+0x70/0x70
[Mon Dec 28 23:38:08 2020] kthread+0x104/0x140
[Mon Dec 28 23:38:08 2020] ? task_done+0x90/0x90 [spl]
[Mon Dec 28 23:38:08 2020] ? kthread_park+0x90/0x90
[Mon Dec 28 23:38:08 2020] ret_from_fork+0x35/0x40
Any advice or help would be appreciated.
Pool config and allocation:
capacity
pool alloc free
z 19.8T 13.2T
mirror 3.27T 2.18T
sda - -
sdg - -
mirror 3.23T 2.22T
sdb - -
sdh - -
mirror 3.31T 2.14T
sdc - -
sdi - -
mirror 3.33T 2.12T
sdd - -
sdj - -
mirror 3.23T 2.22T
sde - -
sdk - -
mirror 3.20T 2.25T
sdf - -
sdl - -
special - -
mirror 226G 29.1G
nvme1n1p3 - -
nvme0n1p3 - -
logs - -
mirror 0 15.5G
nvme0n1p2 - -
nvme1n1p2 - -
cache - -
nvme0n1p4 596G 10.7G
nvme1n1p4 596G 10.4G
