HI GUYS!
Question 1: is it worth it?
Question 2: I'm thinking r9 270x 4gb sli or 760 sli or 780 or r9 290. Which would be best?
Question 3: Should i use the same type of monitors? I already have a vs247h-p, and I don't love its color and such, so i was considering getting 2 badass 1080p benq monitor instead.
THANKS 4 HELPS AND -INGS.
if anyone could possibly help me...
anymore answers to the other questions? possibly?
The 3 x 1080p monitor setup is really cool to play on, it offers a much more immersive experience than a single monitor, although 1440p monitor lovers would love to argue that point.
Either go 780 or r9 290, sli/crossfire is not as reliable and is a minor fps improvement over the 780/290.
You don't have to use matching monitors. Something with slim to no bezel is always the best. I'd get a really nice BenQ, Asus, LG or Samsung panel for the main monitor. And maybe get a second vs247h-p to use for the right and left monitors. I like the symmetry and the less deep colors won't make as much of a difference if they're not in your main vision.
interesting... so i shouldn't cheap out on the monitors, right? (and as far as i saw, sli seems to be a pretty steep performance increase compared to a single 780/290.)
The side monitors are ok to cheap out on a little. They aren't as important to the gaming experience as most of the time you'd use the center monitor for your "main" game activity. You use the side monitors, just not as much, so going with a panel that has slightly less color depth, is ok. Just make sure it has a small bezel. Main monitor, no, you need to put in more cash because that's the panel you'll use the most.
Sli/Crossfire vs Single card. You can run into a lot of problems with sli/crossfire (not as much for sli but still the chance for a lot) such as micro stuttering or the game not being optimized for 2 cards. Most are but some have miniscule performance gains. bf4 for example had major problems. People running 2 x Gtx 770's had sometimes worse frame rates with 2 cards compared to using 1. Most had about the same as with a single card but still, a single 770 for 3 x 1080p is rough. Nvidia JUST got a new Sli profile to fix the problem and the game is months old. Its usually easier to run a single card then 2. I saw a guy selling of his R9 270's a week or two ago here because Skyrim performed horribly with them. He sold them to buy a 290 because it was such a pain.
THANKS! that answered everything :) one last question: should i go check out my friend's setup to see if i want to go triple monitor? im actually still not 100% on boat.
That's always a good idea. You should also see if you can try out a 1440p monior. You can get a 1440p monitor from some non-name brand companies for around $350 if you look around on Amazon.
i did see a 4k monitor and as awesome as it was, it just didn't seem to pop out SOOOO much to its value. I think 1440p/1600p will most likely be the same :/ maybe i should just save da money and keep my crappy vs247h-p :P
