I am getting ready to build my first PC. Any tips that will help me not explode my new PC are greatly appreciated.
Thanks,
Doughnut
Thanks,
Doughnut
Well, make sure you're picking compatible parts, that the PSU is 80 Plus certified, etc. There are some general things, like:
PC building isn't that difficult if you have a general sense of which plug goes into which socket, etc. Just make sure your workplace is free of cats/dogs, liquids, or something that might really ruin your day. Have fun!
What is the easiest was to discharge any static electricity?
wear shorts that don't cause static, sit down with legs crossed, place case on legs, ???, profit
don't sit on carpet, wood floor would be best
Ground yourself. Always ground yourself.
To discharge yourself touch metal on computer chassis to negate any charge differential between you and the computer ;)
Dont use a hammer.....
+1
Just touch the case before touching any of the components. As soon as you start building, you will be touching the case so much that you don't even have to thing about it.
What are shorts that dont cause static?
