So basically I have an old rig with 2 HDD's on it. They are both SATA. One is 80 gb and has Windows 7 on it. The other one is 500 gb and has all the data on it. Is there any way that I could transfer both of these HDD's into a new system? Another option I could think of is using dban.org to wipe the HDD's and install windows onto the 80 gb hdd.
Also, the point of this isn't to keep the data but to not waste money on a new hdd.
Wipe the 80GB Drive solely for windows. Then just install both into the new system. This is exactly what I've done in the past with some clean up on the larger storage drive.
Might be best to wipe both and make sure they are both using the same file system? Someone else will have to chime in on this, but that is what I would do just to be safe.
i guess that works aswell. And also, I dont really want to spend 100 bucks on windows. I want to do the "other" way. would you recommend a specific link that wont give me a virus?
