I have not been able to find the information I am looking for anywhere online. I am unable to get Ethernet into my new office. If I use this tp link ax1800 as a wireless access point it says I can connect Ethernet to devices without wifi.
My question is, if I run the ax1800 into an Ethernet switch, and then have multiple desktops connect to the switch via Ethernet, will this work?
I understand that it may limit bandwidth if multiple desktops are working at the same time, but I am less concerned. This is primarily as a cost saving measure so I do not have to buy multiple wifi cards for desktops that only have Ethernet currently.
I think youâre a bit mixed up⌠it sounds like you do NOT want to âuse this tp link ax1800 as a wireless access pointâ, rather you want to use it as a wireless client.
Any router that supports âclient modeâ will no longer work as a wireless access point in this mode but yes, it can provide wired connections to an existing wireless network.
These wired LAN connections are generally no different than if the routerâs WAN port was connected⌠theyâre just regular LAN connections so switches will work just the same.
Yeah⌠terminology seems to vary quite a bit between routers. The router Iâm running now has freshtomato firmware installed and itâs in âwireless ethernet bridgeâ mode to provide wired connections but it also has âclient modeâ and âbridge modeâ. They all work similarly with the differences being how the networks are integrated (and that bridge mode was constantly dropping the wireless connection).
TP-Link seems to support âclient modeâ so I just went with that⌠but yeah other modes may offer similar functionality. I think bridge modes tend to integrate with the existing LAN rather than running an independent LAN which may cause issues with a switch depending on how the existing wireless network is setup.
Thereâs always a bit of pissing about with these things though. Iâd just start with âclient modeâ if itâs an option and explore other bridge or even repeater modes from there.
I want to connect to my existing wireless network with this device. This device will then provide Internet access to an 8 port Ethernet switch, thus allowing me to connect Ethernet only devices to my network, via the to link wifi accessing it
So, just to check, your internet/up-link connection is coming through ethernet or WLAN?
I think you should be able to use the wireless router as just a switch. If you feel like something is still unsure for you, please try to make a basic diagram (boxes and connections between those boxes is good enough
If I understood correctly, you want to get some internet connection to your new office, but you donât have access to wired ethernet internet access/up-link access?
In case you already have an internet connection at the office, you might need a mesh system if you donât want to run ethernet yourself.
Here is my little diagram of the basic setup
Internet router --Ethernet-- Mesh Router node A ~~Wireless connection ~~Mesh node B at your office--ethernet to the rest of the devices
If the office doesnât have an already exisitng internet access and you would like to go with mobile broadband, you need a specific mobile broadband router. The TP-link AX1800 does not have that feature. It works only with an existing ethernet uplink/internet access, you probably wil not be able to use that specific router as your primary router.
