I'm looking to buy a new mobile phone, and although I'm into my tech, I do not keep up to date with mobile phones, long story short, I had a Galaxy Note 4 since it was new, and now apparently it's beyond repair. I didn't actually damage it, I think that the internals have experienced heat damage or something, I took it to be repaired, all that was wrong is that it was showing symptoms like the battery was dying. It would just randomly shut down, even with 80%+ battery life. Well anyway, they took it to Samsung because they couldn't repair it themselves, and apparently Samsung turned around and said that they refused to try and fix it.
So, now I'm just using a crappy second hand phone, and when I say crappy, I mean it crashes when I just try to reply to a single text, let alone run any social media app(s), or pretty much any app that doesn't come with the device out of the box. It's great because I've had it given to me for free, it's one of my relatives old phones, but time has taken it's toll on the poor thing, and apps just keep getting more demanding, it just can't keep up, it was even a low budget phone when it was brand new.
I'll cut to the chase, can anyone recommend a phone that meets the following criteria:
- It isn't made by Apple (nothing wrong with iPhones, just cba for their software)
- Has a damn fine camera - [Biggest deal breaker for me.]
- Isn't sluggish when loading/running apps, but also doesn't have to be instant.
- Size I couldn't give less of a f$!k about, as long as it isn't stupidly small OR stupidly big.
- Isn't too cheap but isn't the most expensive thing you can find either.
I personally feel that after my experience with the Note 4, I will NOT bother buying a flagship phone, I'm not sure if anyone else agrees with me on this one, I just think they're WAY over rated. Don't get me wrong, when the Note 4 as working, ti was great, but even then, it just didn't seem like it was the best of the best, I didn't feel satisfied considering how much it cost to buy.
I originally went for something top of the line just because I LOVE my gadgets and hardware, but now I just feel like they're over rated on a new level.
