I’m currently wondering if i will have too many devices. Currently I run 1 server with 1 Pfsense router and another HTPC. I have my T440p as my main PC.
I placed a reservation for the Steam Deck just before I got informed by Lunduke that the DevTerm exists. I also plan on getting a Main workstation with either ZEN4 or TRWX.
I don’t really want to have too many devices on me as I still have a Samsung smartphone which I’m thinking of ditching for a Pinephone and a Pixel for photos and other business calls.
If that all comes I would have 9 devices of which 3 I would have with me on travels and 2 mostly on me.
The first three devices I would probably leave as is but a new laptop could be a replacer for something… As with the devterm I would hope I could utalize it for network monitoring, diagnosing, I kinda don’t know but it looks cool.
Not sure about the phones, I hate being tracked and even less so by companies that have no concern for privacy. So I thought of trying a Pinephone, maybe a Pixel as it has the Graphene OS, but I would wait for the new Pixel 7…
I would ask you, how can I consolidate better, what would you go for and is there anyway to reduce the chance of buying a device and having it just sit on the shelf the whole time it is somewhat relevant?
Also forgot the idea of getting a smart wrist watch although I already have Datarunner Digital and Analog for just time. And maybe having an extra for playing music/radio, phone always seems to be full of other things and I can’t always spend data on loading from roon/plex.
And besides all that I would want to make a smarthome so would I run it in a Docker on my HTPC or on the off-site server?
Phone
Tablet(hardly ever used anymore)
Laptop
Home server + a bunch of Raspberry Pi’s
Secondary NAS as backup target
Router, and a few switches
Linode VM so I can do the HAProxy + wireguard thing for remote access
The plan is to run most servery-type things run as VMs or containers on the home server. That should help towards maximizing efficient power usage while still having some options available in case something dies.
Why? Is it because of the hardware or the Manjaro software?
Well in my case I only have two pockets that I use on my pants, one only has room for one or maybe two phones, but it would weigh and be a hassle.
I just have two bags of which I only carry one of them at once because it just is uncomfortable. One can carry a laptop and the other has like small device space.
I just don’t want to feel like going outside and then noticing, now would be a nice time to catch up in Forza or something. Or forgetting the work laptop, oh ye, forgot this too,
My phone can’t do everything and I’m annoyed by it. It should be more like Pip-boy / devterm, on which I could play abit Forza or connect an ethernet to check link speed or be actually useful for work…
Like I have kinda a hard time choosing, I don’t want to waste money
It probably isn’t too many devices but too many overlapping purposes maybe?
I remember reading about DevTerm on Twitter, a few commented how a single core RISC-V processor is going to seriously cripple it as more power efficient dual-core RISC-V solutions reach the market and being an early adopter of tech usually means first gen can be a bag of hurt. In my opinion I’d avoid the DevTerm, if the Pine Phone supports USB devices with an OTG cable, you could likely use an ethernet dongle and get the job done too.
As far as what I view as a decent combo for mobile working:
Windows laptop- certain fields of work you’re stuck with using Windows only software.
Chromebook- upside ChromeOS has the Linux application environment so with any power sipping Chromebook you could squeeze 7-8 hrs of usage per charge & Steam works so you could do remote play. I’d highly recommend a USB-C based Chromebook, just carry a generic multi-port charging brick and two cables(one for Chromebook & other for the phone)
When I buy something I try to step away from any fantasy and enthusiasm I might have and make sure that the device I’m about to buy is something I would actually use, when and where. Also trying not to buy duplicates of stuff I already have, if not necessary. Look online for raw/truthful reviews and last buy if I’m convinced.
For example: I’d be thrilled to have PinePhone Pro but I know for sure that after playing with it for a while, I’d stop swapping my SIM card in it back and forth because I know it’s a device for tinkerers with way more time and knowledge than me.
If you’re the type of person that listens to music those 5 to 8 hours a day and you’re having storage and/or getting to your monthly data cap fast you could get a DAP or, if your device supports it, get a 256GB micro SD card and use that as a player when replacing it for a new device.
Personally, knowing I was upgrading to a phone with no micro SD, I went for a device with 256GB of storage. Maybe you could too and have all the music you listen to locally.
If you mention your HTPC I guess it’s on 24/7 so why not. It’s very light software so it wouldn’t make it sweat.
But, if your HTPC is not on 24/7, maybe running it on the offsite PC could be a good idea.
Right now I have Linux on my laptop and I am fine, just annoying to screen share when Wayland just shows black screen.
But sounds like a plan with USB-C port, maybe an AMD laptop with USB4 which is if I understood interchangeable with Thunderbolt? 1 Cable to power them all.
I get that, I guess I’m just brainstorming what I should do later when I’m in the position of being actively travelling and such.
Things that bother is the small screen of the phone, and when I load it up with the apps I need and then want it gets quite full.
Then when I stop using YouTube Music, I would want to have some way to synchronize my music from my roon/plex or something to my devices. Or I will forget or have no time and boom I’d be 15 hours in a bus with zero to do.
Eh, I already have 2 sim cards and I would have my private in the pinephone.
I have YTM synchronizing my latest findings from few of my playlists when I’m on Wi-Fi so I can listen to a mixtape whilst going to work. Also annoying is that the phone battery doesn’t last so long so I could listen to music after having watched videos for hours…
Ye it would be 24/7 because it has Plex on. But also that it could be used by a friend for gaming also.
I do have cargo pants, just not always. Can’t wear cargos to work. Also I barely ever have anything in the lower pockets because hard to reach or I’ll sit outside or something and it would just rip my legs.
I probably have to do an excel to see how things overlap and see then what is useless.
It’s because of the reality that iOS and Android are often the only platforms targeted by commercial app developers. Even when things like Android app emulation works (it currently does not), you still need to fight built-in fraud detection systems which constantly flag you as being suspicious because your activity looks different. Linux gamers occassionally get banned from MMOs for the same reasons.
So long as you need a single app that uses Google Play, you’ll need an Android device. The Pinephone will not replace your daily driver until you eliminate that dependency and for many people that’s practically impossible.
The Android ROM route also gives you proprietary camera blobs which will take better pictures than Pinephone does, and likely ever will.
I don’t really hold much hope for USB 4.0 “standards” being followed as OEMs can do stupid things as part of their “power budget” on laptops and they rarely list power output of their USB-C ports in the data sheets. For example some 11th gen & 12th gen Intel laptops may it be USB 3.2 or USB 4.0 may not supply enough power out the USB-C port so a USB-C based monitor still needs a dongle to pull power from a USB-A port. I bought a pricey USB-C monitor for my former 11th gen i7 laptop and needed to use the USB-A power dongle… it felt oddly impressive that Lenovo didn’t butcher their USB-C port function on their 11th gen Intel Chromebook, USB-C monitor thankfully only needed a single cable.
Makes sense. So I guess an 8" tablet would work better for you?
Something like that would give you lots of hours of runtime. I’d also pack a good powerbank since you’ll be out for long days.
I don’t bother with two phones, it’s too much hassle. I use two SIM cards in one phone and turn one on when needed. The fewer things I have on me, the better.
Yeah, that sucks! I’m very forgetful too so an automagic tool to sync music would be ideal for you.
Well it wouldn’t take too much resources to run so doing it while gaming would be ideal.
I don’t know, tablets usually are super slow or just lack ports, everything has to be bluetooth these days… I do have a bt mouse, just not a kb yet.
I do have a heavy LINOCELL accu with 20k mAh
The issue with my Samsung was that, I tend to move alot, like in 2 years I moved 5 times, 4 different countries. And I have 2 sim cards one i must have physical and another eSIM, I would want to get maybe a local number, not sure yet tho. But 2 are max amount my S21 can do.
Maybe a Linux tablet or something more sophisticated than the Devterm, that could run plex, youtube and give me the possibility to atleast try to develop some system to synchronize data from my media server to it. Also I do like radio. And eventhough the internet coverage is great, I still get in situations where I don’t have it or it is just H+, so in those cases offline media is great consumption.
Lack ports yes, but there are some Lenovo tablets with Snapdragon chips like the 888+ or the 870 that aren’t too bad to do general computing and content consumption. Or you could buy a Samsung S tablet that I’m sure would work really well and are usually equipped with the latest and greatest SoCs.
So you’re set on that front, nice!
So you need three SIM cards. Another phone is mandatory then.
For sure! Maybe even a 13" convertible? That could be a nice middleground and you’ll have no problems finding a decent one.
That was a prerogative of phones. I guess you could buy a tuner/spectrum analyzer that HAM radio people use to hook up to your PC or phone. I don’t think carrying a whole radio would be a good idea for you, too much stuff to lug around already in my opinion.
Sony used to make these Walkman’s that were just a radio, if I could tune one to have bluetooth or something so I could use my Sony WF1000-4XM in ears.
Can’t really say what’s the best convertible. Depends on reviews and your budget.
I think it could be a good option for you. It’s a flexible device (no pun intended) to do media consumption and some work on.
You could buy a radio and rig a bluetooth transmitter in it for sure. To do that a cheap one would be best so that, even if you mess it up, it’s not a portable DAB radio that costs 100$.
