Tomb Raider playthrough
Hi guys, I'm doing a tomb raider playthrough on youtube- It has no commentary or anything. If you wanna watch, go ahead..
Plz watch it
http://youtu.be/BDMUxLBPGUg
The video will be live after 1 hour of this post.
Recorded on a PC @ 55 fps average on maxed out settings.
Computer specs- Amd Fx 8320
ASUS M5A97 r2.0 motherboard
HIS IceQ Radeon HD 7870 2gb GDDR5 video card
Recorded with fraps.
Is TressFX on? That feature completely demolishes my GTX 650. I literally go from 80+FPS to 14 with TressFX enabled. I'm tempted to throw in my 570 to see how Fermi handles the issue.
Vid is still being processed...
UPDATE: Video removed for being too long.
There are massive frame rate and stability on Nvidia cards. Nvidia has acknowledged the problem and there should be a fix later in the month.
I don't have any frame rate issues on my 670 but with tesselation Enabled I get frequent crashes
Yeah, the game crashed for the first time when I enabled tesselation, but that as after quite a bit of playthrough. So much nVidia makes better drivers...
Yeah I really hope they fix it soon. I started playing today but could only play for about 15min before it started crashing.
you're link is closed mate
