8350 stock
7950: 1080 core, 1500 mhz memory
Tomb raider benchmark utility at 1080p ultimate preset with vsync turned off 55.7 fps.
Is this a low score ?
8350 stock
No I get ~40-44 on the benchmark with my oc'ed 7850 (1050 Core, 1400 memory) and my FX6300. it is a pretty demanding game.
EDIT: I don't think that's on ultra so...
Ultra (tressfx set to off)
HD7950 1100Mhz/15000Mhz FX8320@4Ghz
At 1200 core and 1700 mhz memory i got:
ultimate: 62.0 fps
ultra(tressfx off): 92.6 fps
I also noticed that this game really like video memory overclocking, at 1200 mhz core and 1250 mhz memory (stock) i got 51 fps on ultimate and after I overclocked the memory to 1700 mhz i got 62 fps. This is the only game I've seen that actualy benefits from memory overclocking.
win 8.1,
8350 4.6ghz + 7970@ 1080 core, 1500 mem
1080p, vsync off, ultra, tressfx off
min: 78 fps
max: 120 fps
average: 99.7
going to redo the test now with tressfx switched on :)
^^ nice try http://unigine.com/products/valley/ if you whant a good stress test.(its free)
with tressfx on
min: 50fps
max: 82fps
average: 65fps
still perfectly playable and the hair looks so much damn better... so for me it's worth switching on in my opinion :D
THREAD NECRO!
Just got a sapphire 290 tri x and thought I would re test
graphics settings in bench are the same as above..
card settings are at the default factory overclock and I get
min: 62fps
max: 96fps
average: 79fps
will spend a little time with some other tests at stock and then overclock, so far its pretty good.
...another thread necro :D
9370 4.5ghz + 2x Sapphire Tri X
1080p, vsync off, ultra, tressfx on
Just got another sapphire 290 tri x(cos they are ludicrously cheap right now :D
min: 108
max: 190
average: 122
apart from the extra card the only other thing different about the build is the catalyst drivers, so it isnt exactly apple to apples
If you getting 122 fps with cf 290x then 1440p shouldnt be to far behind.
I think I could grab a 1440p monitor now and be happy with the performance
