To people with 120hz monitors
Hi, I got a 120hz monitor and my question is do you use it for 120hz gaming, or do you just game on it and have the monitor on 120hz so whenever the framerate is above 60 there is no screen tearing
Certain games I play I'm able to maintain 120 fps, but very few.
So yes, usually I have it set to 120hz in the display settings in windows, allowing it to truly display anything more than 60fps.
Yeah, I have mine set to 120hz in the display settings. For games in which you can change the resolution to include 120hz such as Battlefield, I use that setting.
Depends on the game, though I always shoot for 120fps/hz.
I have that Korean 2560x1440 monitor OC to 120Hz and I game on whatever FPS the game runs at. if its 40 it's 40, if it's 160 it's 160.
I did make a few quick tests at one point with games that get over 120FPS and I didn't personally see the difference between 60 and 120Hz. But 120Hz did remove tearing so it was working. But maybe the pixel response time isn't good enough to make out the difference between 60 and 120Hz.
Alright I have a quick question, do you need vsync for 120hz? like 60hz without vsync there's a lot of screen tearing so basically I'm asking would there be any difference in screen tearing on 120hz without vsync?
If the game runs over 120FPS then yea there is a chance of screen tearing.
The method of displaying frames is the same. Just look up how screen tearing works and you'll have better understanding of it.
If you don't want screen tearing wait for nvidias G-Sync enabled monitor and get yourself a Kepler GPU. Or use V-sync or rung games on so high detail that they don't run over 120FPS.
Would anybody be willing to turn down the graphics to lets say medium @ 1080p to maintain a solid 120fps?
That is an interesting question.
I have turned graphics way down multiplayer games like Tribes Ascend and BF4 to get better FPS but it was to get smooth 80FPS.
And in racing games I am good with 40FPS as long as it's stable.
I definitely will turn down graphics to get better FPS but for it I don't need 120. 80-100FPS is probablt the sweet spot for me.
I use mine for 3d gaming. I prefer immersion to competitive play.
