Tmux scrolling though log?
I am trying to replace screen as my daily minecraft server viewer also in case of power failure of my guest pc, i can know that tmux is keeping the instance running. My issue is i cant seem to figure out how to scroll up past a few lines of the terminal. I cant seem to find any way with a google search to do this. Screen would keep entire history in the session.
Tmux by default only keeps a few screens of history. You can configure that to be larger.
Hit its control function. Default is Ctrl-B. Then press Page-Up to start going back in history. That works for me, anyway.
Thank you very much!
I’ll just leave this here…
Would that be saved as /home/username/.config/tmux.conf on the target machine?
I do that but you need a symlink to ~/.tmux. The openbsd guys don’t seem to care about XDG paths.
And for the plugins you need tpm.
I have this in my .zshrc to install/update plugins silently in the background.
# install/update plugins in background
  ("${XDG_CONFIG_HOME:-$HOME/.config}/tmux/plugins/tpm/bin/install_plugins" &>/dev/null &)
  ("${XDG_CONFIG_HOME:-$HOME/.config}/tmux/plugins/tpm/bin/update_plugins" 'all' &>/dev/null &)
I’m not sure AEG would have changed his shell, let alone be familiar with dot files, Mr dotDotperioddot
idk am i? Are you home mr. trooper?
I’m just finishing work, then will be heading for /home
I got a surprise for you in the server.
I just upgraded to a gigabit down and 40mb up. latency has gone down as well.
