Great build @wendell i like the form factor of the case and the mix of parts, great work.
why not mount a lamp arm onto both sides (outside i mean) off the case as to free up space inside for future mod's, adding a strip off 3d printed material to the screen mount and a profile of aluminium to the sides of the case to mount the arms
maybe i should use some sparetime to draw what i mean, let me know if you want that
Lian Li's page says the case uses a standard SFX power supply. Maybe Corsair or Silverstone could help out? I think a full GPU in there would be amusing.
Would love to see another video @wendell with a GPU as a crazy LAN party build, maybe go over making it again or what you would/could do differently (I know @Zibob is doing an updated version of his)
Yup but that z270 is just unbeatable for the PC I am building. I am much more on the laptop scale of power for mine.
Though if the Deskmini RX would ever hurry up and be a thing that would be the ultimate solution. Mxm 480 and socketable CPU in super small form factor. I would probably ditch the standard case and mount the mother board on the back and then make a new enclosure.
EDIT: @wendell how are you powering the screen? I have an adapter but it looks like yours goes into the case somewhere.
I was going to ask about the display setup and that driver/controller board, but I found it. Hoo boy is it expensive. http://dp2retina.rozsnyo.com/
A little project has been rattling around my brain for a few weeks now: Portable monitor. Essential a laptop screen with multiple inputs (VGA, DVI, HDMI, DisplayPort). Preferably battery powered somehow. Anyone know of a multiple input to single output switcher board of some kind?
Anyway, cool project Wendell. I like the idea of stuffing that much power into such a small space. And yet it is still functional. Love the articulating arm monitor. And that AIO cooler is pretty cool.
No never made a thread about it originally. Also not cheap but I really wanted that wackiness and I use the hell out of it. I love these things. I would love to get 2 more and go triple wide, but try pushing 3 2048x1536 monitors, I don't have the power for that and they are useless to me as desktop screens, only games.
@marasm I might know what you are looking for but it is not really cheap, looks nice though.
I wonder if the Qualia board could work with other panels too...
IIRC the iPad panels are just eDisplayport, and there's a whole slew of laptop replacement panels out there that use the same setup. A nice 15" or 17" panel attached to a moderate sized case would be amazing for a LAN party.
I used a controller board from a company called AbuseMark in Japan and have had good results. I put an iPad display on the front of my Corsair 250D.
I also added a HDMI switcher and a Raspberry Pi 3 to the back of it so I could have RetroPie for a separate arcade box.
It's great at our LAN Parties when two people can play classic arcade games and I can still play my PC games without getting interrupted. My only issue is that the new micro HDMI controller board only works with iGPU. I also have the DisplayPort Board also which works great with my Graphics Card but I can't use my HDMI switcher with the DisplayPort Board.
Instead of X99 why not just use the 8c/16t Ryzen chip when it finally drops? And possibly a Fury nano or something for the GPU, although perhaps you could do a reference or other short PCB 480, and do a custom loop inside that thing
