I have been rocking a PC for some time, Its starting to feel its age slightly
its a:
AMD FX-9590 / Thermaltake aftermarket cooler
GTX 970 (zotac)
8GB Ram (really bad ram)
Crucial M500 1TB SSD (I used to be rich once)
Some cheapo mobo ASUS M7-something
a 800w power supply
Now the question I am asking is: I use it for gaming / using adobe suite, I have found that it wrecks the electric and new gen processors seem to offer more bang for less TDP?
I know I could salvage my gcard and SSD as they are still going strong (I am sure my gcard could use a re-thermal paste though)
I have not even looked at PC parts properly in ages and just feeling a bit blown away by all the choices.
@UHI it’s hard to make a recommendation without a budget and it would be helpful if you had posted if you prefer Intel or AMD since your current desktop is AMD I assumed you would be sticking with AMD. Keep in mind you will have to check with ASUS and see if the memory I picked is compatible with the particular motherboard I picked. Also, remember you will need to purchase a new Windows license for your new build. You probably won’t be able to transfer your current Windows license without a call to Microsoft, and I doubt they will allow you to transfer the license.
One issue with that board - since I have suffered some sort of hardware issue that I’m troubleshooting myself, I really regret not getting a better motherboard with some sort of troubleshooting features. MSI puts LEDs for troubleshooting on their B series boards all the way down to B350, Gigabyte have some sort of troubleshooting LEDs, I guess post code is our of the price range…
I think my budget would be around 500 quid ($653) +/- 10% I would deffo like to stick with AMD because they seem to be doing GREAT at the moment and I have basically never really been able to afford or justify buying a Intel processor all my life NOT a fan boy and if there was a compelling intel option I would be willing to try.
Also With regards to my OS I have windows 10 already, I usually have to upgrade from windows 7 disk (the old upgrade free path) I have HOWEVER, do I have to buy a new OS for a new system these days?
I would also like a board with m.2 on it so I can load Linux/windows onto a drive in the future if I pick up some m.2 drives down the line. Whats the deal with swapping m.2 drives and just boop, it loads?
Also really not interested in RGB, I am a 34 year old sod and I want my room to be darker then the darkest night when I am sat there playing EVE online, MTGO and drinking beer trying to forget my crappy shifts. Don’t want to feel like I am in a drum and bass night.
It is thought to drop sometime mid-year, so around June or July. I don’t expect any more information from AMD until sometime after March, so we won’t know when Ryzen 3 will drop for sure until then. If you decided to install Linux, do yourself a favor and purchase a separate storage device for it. Management of Linux will be easier if Linux is on its own storage device. Also, I would down grade the motherboard before I would do without a UPS. You didn’t mention if you already have one so I assumed you don’t have one already.
Cheers yeah this is why I was asking about that m.2 slot. The UPS still has legs in it yet so I think I am only asking for a mobo / memory / processor upgrade as it stands.
Like @Shadowbane suggested, Ryzen5 2600 (maybe X when you can find one on sale), B450 mainboard and decent RAM (16Gig come in handy from time to time and prices are okay-ish).
As you are rocking a space heater of a CPU, I assume you got a beefy cooler.
Word, I think I will stick with the cooler that comes with the processor and upgrade when / if I know. I have only looked inside my pc to clean it out monthly and that’s usually a quickjob :).
When I get back from shift tonight (night shift again) will do that
Was actually just thinking then I wouldn’t mind getting the size of my pc down to mini/micro atx its nice having the tower and all but I live in a small bedsit type room and getting the size of it down.
Well then if the UPS still has legs than I would agree with you, need only need a new motherboard, memory, processor, and a new Windows license. I would try and see if you could transfer your current Windows license, but as I said before Microsoft might not let you.
If you are planning to go with a Ryzen 7, I would upgrade the motherboard from a 450 to a 470 because I have read most X450 motherboards don’t have enough heat protection for the amount of heat a Ryzen 7 will produce. You don’t need to get the most expensive X470 motherboard any X470 motherboard will provide enough protection for a Ryzen 7. Also, I would forget about M.2 storage for Linux, I would stick with a regular SSD drive for Linux. The drivers for M.2 storage are still hit or miss on Linux, at least that is what I have read. While @stconquest is probably correct about the case you pick out being starved for air, You might be able to run your desktop without the front and top panels, If you clean your case as often as you say you do. I don’t know if running your case without the front or top panels will hurt the desktop. That something you will have to ask.
