Tiking Noice
Hi i have a cosair tx650 and it gives a little tikking noice.
If anyone have a fix, or know what it could be that would be awsome :D
Thanks
http://youtu.be/Tx1XIm6q4r4?t=1m35s
RUN FOR YO LIFE FOOL!
How often is the ticking? Is it a constant tick or every now and then. Does it also change depending on load?
It could be just the fan, but if it isn't ditch and get a new one.
No it is a consistant ticking, and does not change on load.
It is still under warranty, so i guess i could get a new one, or should i try to pull it out if my system and clean it with air?
