my ti-84 iv’e had for years was working fine 2 days ago then it would not boot I replaced the AAA’s with good fresh battery’s and even the proprietary backup battery it turns on in a boot sequence and says “waiting please install operating system now” it won’t detect in the TI Software and the cable works because my friends ti-84 plus CE detects fine any ideas
Whats the PCB look like? Any blown components?
nope hoping not to open it up just yet
If it isn’t recognized by a know good cable something should be wrong on the circuit. If you fix that you should be able to load the OS back on it.
opeining atm ill update pics
There isn´t much to go wrong in them. There is one memory chip and a big “magic TI sauce” chip that handles everything (I/O port, USB, keyboard, display can even do color).
The only thing I can think of is that one of the elko´s (large round capacitors) went short circuit and now the memory/storage chip does not get stable enough power to supply data.
Edit: Oh, there is a picture!
Take a look at those two. If one seems to have a buldge on top, replace both.
