Thunderbolt or USB-C dock/hub recommendations for macbook
I have a DP KVM from level1techs, and it works great… with one minor annoyance. Its connected via DP to my windows PC (no issues, even with long-ish cable), and to my work macbook air via USB-C cable matters hub and very short display port cable to the KVM.
Occasionally, I get a black screen for a second or so when using the MBA. I’ve gone through a bunch of different cables for the hub->kvm link, I’m reasonably sure its not the cable. Which makes me suspect the hub.
So, my question: What would people recommend? My requirements are:
USB C or Thunderbolt input
and on the other end:
  • displayport (needs to support 4k 60hz)
  • ethernet (1Gbps is fine, the current cablematters one is only 480Mbps that’s fine)
  • PD either passthrough or powered, either is fine - I have slightly preferred passthrough because it makes cabling easier on my desk, but I do wonder if this contributes to my woes.
  • 1x USB to connect to KVM for kb/m
The options seem to be a selection of cheap things I have little faith that will work reliably, or very expensive docks with 17 ports I have no use for. I feel like a thunderbolt hub/dock has a chance to be more reliable, but don’t have a lot to base this on.
There is also I guess some alternative kind of options, like a could get a thunderbolt hub and a bunch of dongles… but I’m not sure that is better.
Please suggest!
I should update this. I tried 4 or 5 different DP cables (from well regarded brands, including cable matters and club 3d), and it was quite interesting to see the variance across even “good” brands. The best cable worked mostly, but still had black outs occasionally and small bits of noise.
This was driving me nuts… and I probably spent $150 on cables (AUD, but still!). I decided to get the best, to ensure it’d work and grabbed a Caldigit dock… and it’s rock solid. No flickering, no problems (after connecting the KVM USB to a thunderbolt port as reported elsewhere).
I didn’t want to go through 3 or 4 “cheap” docks trying to find one that worked.
