Thunderbolt monitor = DP alt. mode + charging?
Hello everyone! My quest to find the perfect monitor for me in resolution, features, size etc. is not over unfortunately.
I stumbled upon the LG 38WN95C that looks like would work at 100% resolution scaling for me with a good mixture between productivity and gaming.
It’s reported on the box that it’s equipped with Thunderbolt and 94W charging. My work laptop doesn’t have a Thunderbolt port but it has a USB C that works in DP alt. mode and accepts charge at the same time.
I couldn’t find any answer to my question so maybe there’s someone that knows if Thunderbolt is flexible like that when the connection is offered by a monitor and not a PC (I know a PC can accept charging, video out or USB signal through a Thunderbolt port).
Thanks!
In theory, it should work fine. But one thing you need to make sure of is that both devices support each other’s DP standard.
I’ve got a HP EliteDisplay S270n which will happily work with several laptops, even a Samsung Note8 and S10e. However, my Surface Pro 7 tablet won’t work it, seemingly because it only supports DP 1.4 and nothing lower.
Just keep the specs in mind at least. There’s no reason why my Surface shouldn’t work with the display, but sometimes there’s weird quirks like that.
Thanks a lot for the answer!
The PC is new enough and works with a similar HP display I have at work. My phone also works with the same display.
So I should bother LG until they give me the specs on the video signal accepted, right? There’s no mention of DP version supported by the monitor over TB3, else I wouldn’t have bothered the forum.
PD-Charging should be basically independent of Thunderbolt, so work equally well or buggy no matter if using a TB connection or not.
The 2nd generation of TB3 controllers (Titan Ridge) and newer are also backwards compatible with DP Alt Mode (and because the older version did not support DP 1.4/HBR3 this monitor has to have Titan Ridge).
But so far I have seen no TB Dock or other adapter with an option to choose between USB3 + DP Alt or USB2 + DP Alt mode for when in backwards compatibility. They all use USB3 + DP, because I suppose if you want the full DP bandwidth you should just use a TB host.
So, if DP-Alt mode works, the monitor will most likely try to establish a USB3 + DP Alt mode connection, which will only give you half the bandwidth of a full HBR3 connection, which would limit you to 75Hz, 8 Bit at most.
LGs manual does not mention anything about using the TB-in with non-TB hosts, so the support the TB controller has for this could be buggy or even disabled. But as far as I understand it, the controller should be able to do this backwards compatibility all by itself. So my guess is, that LG would have to explicitly forbid such a feature. But like I said, even if present, could be buggy, especially if the rest of the display is not tested with such halved DP connections etc…
HP has a BIOS option in their business notebooks, to forbid the notebook from establishing a USB3 + DP Alt mode connection, to force docking stations without their own switches into USB2 + full bandwidth DP connections, but I do not have access to such a device and therefore cannot verify, if Intels TB controllers can even do this (on the client side. the host controllers definitely can).
Edit:
the troubleshooting part of the manual sounds more like the monitor officially supports alt mode, just not with the shipped, active TB3 cable. So you would definitely need a passive TB3 cable, TB4 cable or a (Vesa certified for HBR3 would be best) USB-C cable. Gen2 USB-C cables should probably be good enough if only 1m, but certified as TB or Vesa would be better.
Thank you very very much for the detailed explaination and research done for the topic. Sounds like it’s exactly what I need.
